Possible transmission issues?
Old Jan 30, 2020 | 06:16 PM
tkstock's Avatar
tkstock
My truck started doing this today while driving home in heavy traffic.
https://photos.app.goo.gl/2BhQgF7Y7wmNABic7
It only did it at really low speeds when I was coasting to a stop. The sound / vibration comes at the end of this video (which is 19 seconds long).
Thoughts?
Old Jan 30, 2020 | 06:28 PM
ford390gashog's Avatar
ford390gashog
Broken snap ring. Sounds like you will be digging into it.
Old Jan 30, 2020 | 08:07 PM
tkstock's Avatar
tkstock
Digging into the transmission is above my pay grade. Plus, I don't have a shop lift or the time to do this repair. I found a video how to do it
, but seems like it would take some time for sure - time I don't have.
Old Jan 30, 2020 | 11:07 PM
ford390gashog
Just have a shop do a transmission rebuild or swap a reman.
Old Jan 31, 2020 | 12:02 AM
Fifty150's Avatar
Fifty150
A remanufactured transmission can be ordered and installed. Those come with warranties. A lot of transmission shops will try to sell you into letting them rebuild, or buying a transmission from them. Less profitable to simply install a transmission which you ordered yourself.
Old Feb 1, 2020 | 11:55 AM
tkstock's Avatar
tkstock
As it turns out, the Ford Dealership determined it was the VCT solenoids. They are also re-programming the PCM.
Old Feb 1, 2020 | 02:37 PM
ford390gashog
Have seen this incorrect diagnosis many times. The VCT solenoids and phasers noise is distinctive. The dealership also knows that of it was in fact a timing issue you do the whole job including the oil pump as a "total" rapir and not a bandaid.
Old Feb 1, 2020 | 02:49 PM
tkstock's Avatar
tkstock
Why would you replace the oil pump on a timing issue?
Old Feb 1, 2020 | 04:40 PM
redfishtd's Avatar
redfishtd
Phasor operation is run by dirty oil pressure thru vct solenoids by command of pcm .Oil pressure determines where cams are supposed to be. Ford oil pump is marginal at best .Leaking tensioners etc they will not be where they are supposed to be .
Old Feb 1, 2020 | 06:04 PM
ford390gashog
Why would you not it's part of the repair. The stock oil pump is fatally flawed and caused lots of issues. The pump is to be replaced with a full timing job. It's not optional its required. The phasers also get replaced along with chains, tensioners and guides. You don't just replace VCT solenoids.
92 Black Nite
1978 - 1996 Big Bronco
Dec 23, 2012 10:44 AM
66gpw
May 8, 2010 07:44 AM
Bart R
Feb 20, 2008 05:20 PM
dr_bob
Jun 7, 2007 02:35 PM
