If one wanted overdrive?
Old Feb 8, 2020 | 01:43 PM
  #31
Enzothehound's Avatar
Enzothehound
My feelings exactly F-250 Restorer. I love working on my dent and improving it. It beats going to a casino or being holed up in a bar though it’s just as expensive. 😎 It’s just good all around therapy.
Old Feb 8, 2020 | 10:12 PM
  #32
tbear853's Avatar
tbear853
Find a old car or pickup 3 speed manual transmission, 3rd is high or straight through, 2nd is like 1.45 to 1, flip it backwards, make frame mounts, put U-joints on it, connect it in rear driveline, just use 2-3 lever, when in 3rd, you're just in high, but when you slip it into it's 2nd, that 1.45 to 1 is reversed, it's now a 0.689 to 1 overdrive.
How they done it a lot in old days …. like when they made tractors from old car & truck parts.
Old Feb 9, 2020 | 04:36 PM
  #33
F-250 restorer's Avatar
F-250 restorer
Years ago I read a fascinating thread about Brownie aux OD's and how to make your own OD, and by using two transmissions, etc. It was amazing and I wish I understood it all. I went looking for info because I had an old Borg Warner R-10 three speed OD with electric OD. The trans supplied either three low or three high gears. My research revealed that parts were hard to come by, especially replacement gears, and since the trans with non-synchronized, gears were severely worn. I sold it and the guy that bought it said he only wanted the tail section, the OD, which he was going to mount separate from the trans he had. That made go and read up.
Old Feb 10, 2020 | 12:48 AM
  #34
Mitch Huested's Avatar
Mitch Huested
Smile
85e150, thanks for the article threads! Very informative
Old Feb 10, 2020 | 10:00 AM
  #35
uniwagon's Avatar
uniwagon
I have a 6041 spicer auxiliary in my 79 F350.It works great,two stick choice of 16 forward gear and 4 in reverse.Truck has 4.10s in the rear and in overdrive takes it down to a 3.52 final drive.Also you can't flip a 3 or 4 speed backwards.They will not get the proper lubrication and you will break the input shafts.They aren't designed to work that way.
Old Feb 10, 2020 | 10:36 AM
  #36
niko20's Avatar
niko20
Originally Posted by ford390gashog
Cost was 4k when I did mine. The gear vendors is not my choice as you will cook the transmission. Remember without a lockup torque converter all you are doing is building a ton of heat when in overdrive. My last build was with a GM 4L80 behind a 390 and that was a drastic improvement over the E40D. Currently working on a 6r80 behind a 410 in a galaxy and that has been time consuming but will be far ahead of the E4OD or the 4L80.
Can you expand on the details of this? Why would you be building up more heat when the transmission is turning SLOWER?
Old Feb 10, 2020 | 02:16 PM
  #37
00t444e's Avatar
00t444e
Overdrive is a higher gear so it puts more load on the engine which makes the converter slip more.
dbreckman
1997 - 2003 F150
Sep 23, 2019 09:01 PM
Cracker289
Aug 24, 2012 12:44 PM
chews32
Oct 10, 2004 06:04 PM
