1978 - 1996 Big Bronco
88 bronco help
Old Jan 30, 2020 | 04:38 AM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
Hey yall I have a 88 bronco with 680k miles on it. The engine is a 351 Windsor with an EFI system. My supervisor gave it to me for free after he couldnt figure out what was wrong with it. It sat and wouldn't start for a year with him. When I got it, One day it just up and started randomly and ran perfectly for a week. I changed the battery, fuel filter, and installed nickel sparkplugs to it. It cranks but wont turnover completely. I need help figuring out of its a compression, or fuel issue. Thanks very much !!!
Old Feb 17, 2020 | 10:29 PM
TechTrev's Avatar
TechTrev
Try spraying some fuel down the throttle body while cranking. If it starts it is a fuel issue. If it does find the valve on the fuel rail, it will look like the end of a tire stem. Use that to see if you are getting pressure to the rail. If you are use a noid light to see if you injectors are popping.
Old Feb 17, 2020 | 10:36 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
I'm an aspiring mechanic so ima have to google how to do that, but I will definitely try it. I'm in alaska so I think it being 20 degrees outside probably isnt helping the fuel problem.
I did replace the air filter with a new one so it can breath better.
Old Feb 17, 2020 | 10:49 PM
TechTrev's Avatar
TechTrev
I can take a pic and send it tomorrow. Also listen to see if the fuel pump comes on, you should hear a low hum come from the fuel tank area.
Old Feb 17, 2020 | 10:52 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
I can here it prime when I switch the key to the on position. I checked the starter relay too and theres spark there too
Old Feb 17, 2020 | 11:15 PM
TechTrev's Avatar
TechTrev
Okay, let me know when you find out if you have fuel pressure at the rail. Then we can go from there.
Old Feb 17, 2020 | 11:31 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
I just checked the fuel rail, and fuel shot put like a lil volcano so the psi on the fuel rail is good.
Old Feb 18, 2020 | 09:04 AM
TechTrev's Avatar
TechTrev
It sounds like it. Next step is to get a noid light, unplug a injector and plug the noid light in. crank the truck to see if the injectors are trying to pop. And are you sure you are getting spark? A easy way to check this is unplug a plug wire from a spark plug and put a extra plug in the wire set it against a good ground and look at the spark. The spark should be blue if it isn't then fuel is not the problem. Have you tired Spraying gas in the intake yet?
Old Feb 18, 2020 | 05:08 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
I will get a noid light and try that method along with spraying gas in the intake. I installed new spark plugs and checked the starter relay. I'll see if it's getting enough spark 5he way you mentioned. Could it be ignition related by chance?
Old Feb 18, 2020 | 06:31 PM
TechTrev's Avatar
TechTrev
There is no need in having the noid light plugged in and spraying fuel in the intake. If it starts while spraying fuel in the intake it will tell you if it is a fuel or ignition issue.
When you spray fuel/starting fluid give it a couple shots while cranking, don't spray a whole lot in at one time.
Old Feb 18, 2020 | 07:30 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
okay I'll get some starter fluid today
Old Feb 19, 2020 | 07:36 PM
BOOKIEXD's Avatar
BOOKIEXD
Update brother, so I sprayed starter fluid in the intake, and it would catch for 2 seconds and turn off. So with it being 30 degrees outside and possibly a spark issue that's what I think is wrong
Old Feb 20, 2020 | 08:30 AM
TechTrev's Avatar
TechTrev
Sounds like a fuel issue to me but it is not a bad idea to check your spark. The easiest way is to unplug one of the wires from the plug put a extra plug in the wire and set it against a good ground, crank the truck and watch the end of the plug to see if it is putting off a blue spark. You can do that with any wire, I would suggest checking several of them.
If your spark is good then it is a fuel issue.
Old Feb 20, 2020 | 03:29 PM
BOOKIEXD's Avatar
BOOKIEXD
88 bronco help
Olay, I'll check that today
Old Feb 29, 2020 | 02:32 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Not necessarily. You can have pressure but not enough to run. Have you checked for fault codes. They can be present even though the light is off.
As a side note: those nickel plugs were a waste of money. Plain ol’ copper plugs are fine.
BOOKIEXD
Feb 4, 2020 06:18 PM
Johnny Mayday
Jul 2, 2018 02:55 PM
2003DSG30
Feb 11, 2016 10:27 PM
DMANGANNON
Nov 19, 2004 09:01 PM
mikefraz01
Jul 3, 2003 08:26 PM
