Front wheel bearings
Old Jan 28, 2020 | 08:21 AM
GoldCo's Avatar
GoldCo
A bit of a groan while turning right, so will be replacing wheel bearings, races, and seals this weekend (thanks, Rock Auto).
Any tricks or tips for removal/install of races?
Old Jan 28, 2020 | 10:18 AM
Tedster9's Avatar
Tedster9
There's usually a wide spot or whatever in the casting to allow clearance or gain purchase to use a punch to drive them out from the back side, something like that.
Old Jan 28, 2020 | 10:30 AM
raytasch's Avatar
raytasch
Believe Nothing
Suggest you verify the wheel bearings are actually bad prior to replacing parts. Cleaning, purging old grease and replacement thereof is always a good idea if a noise is detected.
Old Jan 29, 2020 | 09:40 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Not to insult you but don’t just get a brass drift and hammer and start whaling on the races. Drive them out a little on one side then a little on the opposite side i e start at 12 o’clock then go to 6 o’clock.
It’s best to use a race driver for installing the races and seals but if your carful you can install them with a brass drift and hammer in the same manner.
Old Jan 29, 2020 | 10:30 AM
Tedster9's Avatar
Tedster9
A socket of the right size will work, or the old race, the trick is to get the new one started without being cocked. Being mindful to be safe and wear safety goggles to avoid chips, all the usual standard disclaimers apply. Void where prohibited. No user serviceable parts inside.
busdriver47
Aug 10, 2015 08:44 AM
Nkelly
Australia Chapter
Jan 8, 2014 04:38 AM
Spaggs
Oct 16, 2008 05:59 PM
pdqtimetrialer
Feb 16, 2006 09:29 PM
