Thermostat
Old Jan 28, 2020 | 06:24 AM
Visurveyor's Avatar
Visurveyor
Thermostat
I am wondering if I should buy a hotter TS? These are my readings at idle. I drove 25 miles to work already and sat in parking lot for a few and temps went down. They where 188 ECT. 196 eot at 70 mph
Just wondering.
Thanks Dave
Old Jan 28, 2020 | 08:45 AM
Syphlyn's Avatar
Syphlyn
I just replaced mine with a stock 192 F ford one.
I usually don't see mine below 190 ever. I would suggest a new 192F. If you go for a 200 F tstat it could push your oil into the 210-215 range which is too hot for a cruising temp. While underload you could easily see 220+
I drove 100km one way to a close town. couple of steep grades. I was unloaded and in boost the whole way maintaining 100kph and this is what I observed:
My highest temps observed at the top of a steep grade. OD with TC locked at 25 lbs of boost all the way up
ECT 200
EOT 201
Lowest temps while cruising downhill once up to temp - ambient temp 30 F
ECT 192
EOT 192
Transmission stayed at 164 the entire trip
Old Jan 28, 2020 | 09:15 AM
HydroTek's Avatar
HydroTek
The T-stat sets the low operating temp for the engine while the PCM and sensors set the high operating temp
Look on the t-stat wax element to see the calibrated temp stamped in
Boil the t-stat on your stove, using a thermometer to check when the t-stat opens -- should be according to the stamping
Running a lower than factory temp will make the deltas seem off -- the factory temp is 192.5F
PS: Running the heater will pull the temps down some
Old Jan 28, 2020 | 11:32 AM
diesel_dan's Avatar
diesel_dan
I wouldn't worry about 188 on a stock T-stat. I went out and bought a replacement because I would see mine down as low as 186 when I thought it should be 190+ (truck fully warmed up). Turns out that they cycle a bit on the low end, or at least mine does. So it lags a bit closing down when the cooling system has plenty of thermal reserve. The more I've watched it, the more I'm convinced of this and I'll be waiting on taking out the Factory 192 until I see it really act up. For me, 188 is just fine...
Old Jan 28, 2020 | 12:19 PM
Visurveyor's Avatar
Visurveyor
Thanks guys
I think I'll just watch it and make sure it don't dip no lower. Spring and Summer will be here shortly. Florida get 🔥 Hot.
Old Jan 28, 2020 | 12:25 PM
diesel_dan's Avatar
diesel_dan
Originally Posted by Visurveyor
Thanks guys
And they can fail on that side too! But that I most definitely watch that and it gets real stable under load (or high ambient temps) once it gets over 192-194...
Old Jan 29, 2020 | 03:22 PM
Yahiko's Avatar
Yahiko
Do you know it's age and what brand it is?
Old Jan 29, 2020 | 03:49 PM
Visurveyor's Avatar
Visurveyor
Duralast. Supposed to be a 190 F. But it stays at 186-188 at idle temp.
Old Jan 29, 2020 | 04:04 PM
Visurveyor's Avatar
Visurveyor
Ow. 4 months +/- Sorry forgot to add purchase date
Old Jan 29, 2020 | 04:34 PM
Yahiko's Avatar
Yahiko
I have found that the ones made by International seem to last the best.
The ones from Ford I only get one winter out of and then they go belly up.
Mind you that this was installed in a 2006 engine.
Old Jan 29, 2020 | 04:39 PM
Visurveyor's Avatar
Visurveyor
I think I'll go ahead and order one, have it here on hand. Only few weeks of winter left here in Fla.
Summer hits I want to be prepared.
Thanks
Old Jan 30, 2020 | 09:06 AM
Syphlyn's Avatar
Syphlyn
IMHO a thermostat is a maintenance item and should be replaced every couple years especially if you don't monitor things!
Old Jan 30, 2020 | 09:56 AM
Visurveyor's Avatar
Visurveyor
I monitor my Delta's. Look at first post and you'll see my setup.
Old Jan 30, 2020 | 11:21 AM
diesel_dan's Avatar
diesel_dan
My worry is one that fails closed vs. one that opens early. The latter you can pick your time to replace while the former can shut you down...
Old Jan 30, 2020 | 11:37 AM
TooManyToys.'s Avatar
TooManyToys.
My OE (Int) T/S lasted for 7 years without replacement, my replacement motor T/S, also International has lasted 7 years without replacement.
