Fella's and gals,
I need some recommendations. I want to upgrade my interior lights to LED and need suggestions. Also, I want to upgrade my tail lights and housings and also the light about the back window. Can ya help me?
2007 Ford F350 PSD 4X4 King Ranch.
Get the correct bulb number from your owners manual, then go to https://www.ddmtuning.com/index.php and find an LED replacement in the brightness and beam pattern you prefer. I have their LED bulbs for the head lights, fog lights, and bed lights and am very happy. Good Luck, Russ
Looked in the owners manual and it does not specify map lights so I do not have a part number. If anybody can give me the part number, that would be a great help.
When I changed out the bulb above the back window (inside) the clip had dry rotted and it snapped off. I had to buy the entire $60.00 part from the dealership. Very concerned about the front map lights.
Thank you,
John Blacksher
Reason: Left information off
