Fuel Pump Doesn't Run
Old Jan 25, 2020 | 08:08 PM
Tom_Co's Avatar
Tom_Co
1999 Expedition XLT 225000 miles.
Initial indications that fuel pump bad. Replaced and did not change issue.
Had to bypass power and connect the pump to my Aux power connector via the DeAccel switch connector
to use car for work.
Need to find real issue:
Fuse Good
Relay Good
power to pump looks good for a few minutes.
Power to energize relay from PCM Power Relay good but relay opens. It appears that the PCM module Gnd path is not present.
What does the PCM Module do to the relay ctrl? Can I bypass it since the PCM Power relay will turn it on and off.
Tom Coughlin
Old Jan 26, 2020 | 07:50 AM
Spaznaut's Avatar
Spaznaut
You could energize it with a hot wire from a run circuit. Is that what you already doing or just a hot at all times? With the cpu controlling the injectors I don't think you could flood the engine if you accidently have it in the run position without the engine running. A hidden toggle switch on that circuit would make a nice anti-theft device.
Old Jan 26, 2020 | 08:04 AM
projectSHO89's Avatar
projectSHO89
If the PCM Power Relay opens, the PCM shuts off and so does the fuel pump and everything else.
You're focusing too far "downstream". You need to focus on the PCM and its power. If the PCM doesn't work, you have a dead vehicle.
Old Jan 26, 2020 | 10:23 AM
Tom_Co's Avatar
Tom_Co
The PCM Power Control Relay is not the issue. It is working fine. The rest of the car works, The Fuel Pump Relay energizes for a short time then de-energizes. It appears that the PCM CNTRL line to relay opens shutting off pump.
I've checked for shorts, gnds and cold joints but nothing. Have no errors but it appears as if the PCM is shutting down the pump. If he PCM s doing this I don't know why.
Tom
alloro's Avatar
alloro
Here are the diagrams for the PCM and Fuel Pump relays, see if they help you.
Old Jan 26, 2020 | 12:53 PM
projectSHO89
It's supposed to do that...until or unless the PCM sees an accelerating crank sensor signal that indicates the engine is firing. The PCM then turns the pump back on via the relay.
That initial pump priming cycle is only 2-3 seconds in duration.
Old Jan 26, 2020 | 02:56 PM
Tom_Co's Avatar
Tom_Co
Thank you for the schematics.
The crank sensor is something I'll look at but I have no codes present. It does come back on but the voltage at the relay coil gnd side doesn't go to zero to energize coil it floats at 6 volts so the relay doesn't re-energize.
For the moment I have added a permanent Gnd to the coil so when the key is ON the pump runs. When I have a chance I'll look at the crank signal.
Question: If the Crankshaft Position sensor were bad would the truck still run?
Tom
Old Jan 26, 2020 | 04:20 PM
projectSHO89
No. If the engine fires, the crank sensor is working.
Old Jan 27, 2020 | 09:35 AM
alloro's Avatar
alloro
FYI, the purpose of the CKS is to tell the ECM when to fire the spark plugs.
1993s
Jun 2, 2019 02:03 PM
jdawest1
Dec 17, 2014 03:34 PM
Bronco POPO
Bronco II
Mar 4, 2011 12:44 PM
chipster6
1997 - 2003 F150
Jan 3, 2007 10:55 PM
lurch
1978 - 1996 Big Bronco
Sep 4, 2002 10:44 AM
