Problems finding a clutch
Old Jan 23, 2020 | 06:38 PM
bassmasterdude's Avatar
bassmasterdude
I have 74 F250 4wd with a 360 that I just pulled the NP435 tranny out of to reseal it. While it's out I was going to put in a new clutch. I ordered a 07-027 LUK clutch kit. The new disc measures 11" the one I removed measures 11 1/2". The new pressure plate does not line up with the holes in the flywheel either. Any ideas on what I need? I really wanted to stick with LUK if possible. I did rebuild this engine 20 years ago and installed a 390 rotating assembly but to my knowledge I used the original 360 flywheel when I put it back together.
Old Jan 25, 2020 | 11:52 AM
alans77crew's Avatar
alans77crew
If I remember (and I probably don't) I think you could only get an 11'' clutch for a 360 and the 390 you could use the 11'' or what they called a 12 but was 11and 5/8 or 11 and 7/8
Old Jan 25, 2020 | 12:08 PM
yardbird's Avatar
yardbird
Every crossover parts finder I see shows that as the correct clutch kit for the 360 and 390. The 460 engine shows a different clutch.
Austin Lowery
Oct 24, 2018 05:51 PM
ATC Crazy
May 13, 2013 02:14 PM
bigred.102
Mar 27, 2011 10:51 AM
OldFordRacer
15
Jan 22, 2008 07:54 PM
78fordf250-460
Aug 23, 2005 08:39 PM
