No. 2 cylinder contribution code
Old Jan 25, 2020 | 04:05 PM
SmackDaddy's Avatar
SmackDaddy
You could have a bad fuel pump or it’s going bad and while you were driving fuel pressure dropped and took out the injector...that is why a permanent fuel pressure gauge is always something we bring up when troubleshooting these trucks. A $100 gauge and sensor could save 8 injectors.
Old Jan 25, 2020 | 04:08 PM
Visurveyor's Avatar
Visurveyor
Has about 3/8th tank have cycled a few times. Thinking fuel pump.
Old Jan 25, 2020 | 04:11 PM
Visurveyor's Avatar
Visurveyor
I'll be putting one in. I have been looking at several different ones online.
Old Jan 25, 2020 | 04:26 PM
SmackDaddy's Avatar
SmackDaddy
I would try putting some diesel in the tank until you’re at 1/2 tank or so and try again.
Old Jan 25, 2020 | 06:10 PM
Visurveyor's Avatar
Visurveyor
I'll do that in the morning. I won't be getting a pump till Monday anyways.
Thanks for your help. I'll post results tomorrow
Old Jan 26, 2020 | 12:36 PM
TooManyToys.'s Avatar
TooManyToys.
That's not a good code to have.
File Type: pdf
Old Jan 26, 2020 | 12:49 PM
TooManyToys.
No need for the images....
Old Jan 26, 2020 | 03:01 PM
Visurveyor's Avatar
Visurveyor
Pump turns off after 8 secs or so when I turn key.
Old Jan 26, 2020 | 03:08 PM
SmackDaddy's Avatar
SmackDaddy
That is normal, that’s why I mentioned either cycling the key over and over until you build fuel pressure or get some to come into the bowl or use IDS to run it or there is a way to hot wire it somewhere under the passenger side floorboard kick panel. I’m sure one of these guys knows a way.
Old Jan 26, 2020 | 03:17 PM
TooManyToys.
P232 is a code for a continuous run, voltage in the circuit when there shouldn’t be, which was reported. Hence the pdf. Misreported?
Old Jan 26, 2020 | 04:27 PM
Visurveyor's Avatar
Visurveyor
Truck is running. No misses. Checking codes right now.
Clearing old and rescanning.
Done---no codes. 😅😅😅
Old Jan 26, 2020 | 04:29 PM
SmackDaddy's Avatar
SmackDaddy
What was the solution?
Old Jan 26, 2020 | 04:38 PM
  #28
Visurveyor's Avatar
Visurveyor
Fuel pump was bad. Tried priming it several times with no luck. Went to Napa and bought whole pump for 238.00 with tax. Come home and opened up and the thing had 2 plugs instead of 3, I was trippin. Toomany toys filled me in on the fuel heater being discontinued and that there was new harness. Installed the above. The I cycled pump 3 times had fuel in bowl. Charged batteries to full and it started up after about 5 seconds of cranking. $450 dollar project. Yahh
Old Jan 26, 2020 | 04:40 PM
  #29
SmackDaddy's Avatar
SmackDaddy
Very good! Glad you didn’t throw parts at it.
Old Jan 26, 2020 | 05:03 PM
  #30
TooManyToys.
Cool. Weird you got the code!
