Cruise control
Old Jan 21, 2020 | 04:08 PM
rla2005's Avatar
rla2005
Originally Posted by sloopdog1
There is a switch/plug/sensor on the side of the master cylinder.
Then the master cylinder has been replaced with a newer version, 1994 and up. I had two 1993 F150 Lightnings, on both of them the BPS was on the hydraulic line near the RABS hydraulic module.
Master cylinder does not look like the one in the image.
Is the Brake Pressure Switch on yours hooked up? If it is and the recall harness is not there...disconnect the BPS immediately.
Old Jan 22, 2020 | 01:56 PM
sloopdog1's Avatar
sloopdog1
Not to hijack this post, but here is mine.
Old Jan 22, 2020 | 02:33 PM
rla2005's Avatar
rla2005
Looks like a later version replacement master cylinder, but it is not tapped for the Brake Pressure Switch like the 1994 and later versions are. As I stated before the BPS on your 1993 model year truck is located on the driver side frame rail near the RABS hydraulic module. The same type recall harness was placed there. If it is not there...disconnect the BPS switch until you can source the proper harness with a fuse and circuit modifications.
Old Jan 22, 2020 | 06:48 PM
sloopdog1's Avatar
sloopdog1
Well, I will look when the weather is better. Source the proper harness? Put a fuse in the power feed, if it is even hot anymore.
Old Jan 24, 2020 | 07:58 PM
Dzldust's Avatar
Dzldust
8th Gear
1993 was the first year for the electronic Speed Control system on these trucks. There should be two mechanisms in place to disengage the Speed Control, the Brake On/Off (BOO) switch (located on the brake pedal assembly) and the Brake Pressure Switch (BPS) located near the RABS hydraulic module on the driver side frame rail. Very odd if both failed. I hope the Speed Control recall has been performed on the OP's vehicle. If not, it's a fire waiting to happen.
weird but my 1994 F150 has a vacuum cruise control setup.
Old Jan 24, 2020 | 08:35 PM
Scndsin's Avatar
Scndsin
You might as well take & post a pic of what you're calling a CC because in a second somebody is going to tell you no you don't.
Just sayin'...
Old Jan 24, 2020 | 09:32 PM
Dzldust's Avatar
Dzldust
8th Gear
bought from old guy that bought brand new in 1994,maybe a dealer add on but this is how it came according to him
Old Jan 25, 2020 | 02:08 PM
rla2005's Avatar
rla2005
Looks like a dealer add-on to me. They used all of the older style vacuum speed control pieces. If the truck came with speed control from the factory the buttons would be on the turn signal stalk, not a separate stub sticking out of the steering column as shown in the first photo. The vacuum reservoir would also be mounted behind the driver side headlight, just like my 1992 F350. I believe that reservoir would also be made of metal not the round plastic ball.
Old Jan 26, 2020 | 08:44 AM
mrollings53's Avatar
mrollings53
If I'm not mistaken cruise control buttons are on the front of the steering wheel. My '92 and '95 F250s, and my mothers old '93 F150 were that way.
Old Jan 26, 2020 | 11:12 AM
tjc transport's Avatar
tjc transport
i ain't rite
even my 88 had them on the steering wheel.
Old Jan 26, 2020 | 11:46 AM
Scndsin's Avatar
Scndsin
... If the truck came with speed control from the factory the buttons would be on the turn signal stalk, not a separate stub sticking out of the steering column as shown in the first photo...
The font on that is definitely not Ford lettering for this vintage, looks almost 70-80ish.
Old Jan 26, 2020 | 12:52 PM
Dzldust's Avatar
Dzldust
8th Gear
Yes an add on ,it doesn’t work anyway ,prob gonna pull it off ,just another vacuum leak source
Old Jan 27, 2020 | 07:57 AM
  #28
rla2005's Avatar
rla2005
Yep...I blew that one, didn't I! Brain fade for sure
ridgerider3
Jul 10, 2009 04:36 PM
rmalottwtes30
Mar 14, 2008 09:18 AM
cruiser8
Apr 1, 2005 11:02 PM
marragtop
Oct 11, 2004 08:45 PM
SimonGrant
Feb 26, 2004 07:16 PM
