IPR, ICP, or something else.
Old Jan 19, 2020 | 06:07 AM
MishMosh79's Avatar
MishMosh79
After reading many other threads I can't seem to pinpoint my answer. So most days my truck has no problems starting. But on occasion it will only start if I pull the ICP connection and then it'll run fine, I plug it in and where on our merry way. Now I do have an issue where the truck has problems firing about 2300 rpms sometimes as well but I don't know if that has anything to do with this issue but it seems to be an oil injection pressure problem. Any ideas?
Old Jan 19, 2020 | 08:07 AM
Bobcatbob's Avatar
Bobcatbob
Do you have the Torque Pro to monitor your IPR & ICP? If not get it asap. You need some numbers.
Old Jan 19, 2020 | 05:09 PM
MishMosh79's Avatar
MishMosh79
IPR duty cycle at WOT was 37. ICP seems very high at 4k at idle and even higher when driving.
Old Jan 19, 2020 | 05:25 PM
Bobcatbob's Avatar
Bobcatbob
4000psi at idle? That can not be right.
How much higher when driving driving?
Old Jan 19, 2020 | 05:27 PM
MishMosh79's Avatar
MishMosh79
Somewhere closer to 5k. Not really sure what's wrong.
Old Jan 19, 2020 | 06:14 PM
Bobcatbob's Avatar
Bobcatbob
5k has got to be pushing some physical limits of the system.
Be carefull if something pops.
Old Jan 19, 2020 | 06:15 PM
MishMosh79's Avatar
MishMosh79
Im hoping that the ipr screen is just clogged and it's causing it to read high.
Old Jan 20, 2020 | 11:55 AM
knottyrope's Avatar
knottyrope
Stumble at high RPM could be injector orings but that would give usually hard hot starts too
What is IPR% duty cycle at cold idle vs hot idle?
If ICP is disconnected, PCM goes with default stored limp mode values when reading on scanner
Old Jan 20, 2020 | 11:59 AM
MishMosh79's Avatar
MishMosh79
The ipr has a very steady 11.50 at idle and ramps up to I believe 37 while driving. Has no issues hot starting whatsoever. I think it's the ICP as it reads super high when idling and driving. It has an issue as well when you push the clutch in while driving that the rpms with drop to 400 and then idle back up.
Old Jan 22, 2020 | 12:22 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Ever pulled the IPR for o-rings?
Is your ICP weeping oil? If so, buy a new Motorcraft unit and toss it in while doing the IPR o-rings.
pilgrimbizket
21
Mar 1, 2019 01:26 PM
WatsonR
Feb 3, 2015 08:18 PM
MagKarl
31
Jan 13, 2013 07:50 PM
strokin'_tatsch
Apr 5, 2010 09:51 PM
03_PSD
Jul 17, 2009 10:57 AM
