I would like to eliminate the big body seam on the roof of my 1949 Ford F-1. Has anyone done this before ? I don't know whether to Mig Weld or get one of those lead kits and do it with real lead. Which would hold up better IF the cab does move around, vibrate etc.... Thanks for any input.
If you've never worked with lead, it's a lot harder than it looks to do it right. It would be a difficult job to lead that entire seam, and if there's any rust or contamination left behind, your lead will fail. Far better and easier, imho, to weld it up, and even that won't be a fun job. My 2c.
The two edges don’t perfectly match up so you’ll have to work the top to meet the back of cab.
like Wayne said, lead isn’t the easiest thing to master. Many years ago I tried using one of the kits sold at swapmeets, the kits the sellershow how easy it is. Well I never could get it to work. Later I met an old timer that could spread lead like it was peanut butter. He leaded every kind of vehicle, even newer cars with paper thin sheet metal. He made look so easy. A few years back I decided to try again but I used the lead old timers have used for decades, 70/30. For some reason I was able get it to work and was able to lead three different projects without a problem. I think a lot of it was I have gotten older and have a little more patience, it also helped to watch a master do it. Not so easy to find some One who can show you now.
Why weld that seam? Could you not just fill it with bondo.
You could, but it would not be a permanent repair. Eventually the bondo would crack, absorb moisture from the backside, rust and fall out. If you just want to fill the seam, they make a seam sealer product just for that, and that would have been applied at the factory. It could be made to look very good with seam sealer at a fraction of the cost or labor. Seam welding is a time-honored custom trick, but it's a ton of work to weld, grind and finish the width of the cab.
You have to realize there is some flex in that area, not much but some. You either have to use a produce like a seam sealer that will allow some flex or something that is going to physically join the two pieces of metal like a metal weld. Plastic filler will eventually fail, maybe not for a year or two but it will crack. I blasted the seam to clean it out, sprayed with epoxy primer and then sealed it with a paintable siliconized sealer. Key word "paintable". If you use a silicone sealer you will end up with a nightmare when you paint it.
Beautiful truck !!! One more quick question . Can typical joint and seam sealer be sanded ? Any applications I've ever seen from the factory look real ugly !
Sure, if you use the right stuff. I'd recommend a 2 part, catalyzed urethane seam sealer, applied over epoxy or urethane primer. The sealer can be laid out nice and smooth, sanded, primed and finished to the point you'd hardly know it wasn't welded. The factory doesn't do it to build show cars, but a half-talented tech certainly could.
I personally wouldn't want to mess around doing it. When I did my cab, and others, I used the stuff that comes in a long tube you install in a caulk gun. Cut the tip so I had a small hole and laid it into the seam, smoothing it out with my finger, wiping the excess with a cloth.
I have had good success with "stitch welding" the seam and then filling the gap with panel adhesive prior to smoothing it over with a skim coat of body filler. The stitch welds only need to be about every couple of inches to ensure that the seam will remain stable. The biggest issue with this job is cleaning out the factory goop that is down in the seam to make it waterproof. That stuff will really make a TIG arc spit.
