Finally got my MAGNUM LOW PROFILE backrack on. Very impressed with the build quality of the rack, welds and finish. The install was very simple as well. I got the center white lights to be a strobe and wired it to upfitter 1. Instead of having them reverse lights.
Picture is a a bit deceiving but the top is exactly lined up to the top of the roof.
Looks great! Can you take a picture in the bed pointed down at the rack/back of the bed so I can see how far back from the window the rack sits into the bed?
I have the cover pictured below. I know it will fit between the rails, but I’m not sure if I will still be able to fold it up.
I don't care for their mounting block system but its what I'm using. It isn't as solid as I'd like. If I were a contractor putting heavy loads on it I'd bolt it directly to the bed for rigidity. They do seem to be very well built otherwise.
All I need mine for is a couple lights, the occasional ladder, & of course rear window protection so its fine.
thanks!
Any love from any of you with them so I can tell if it will fit with my cover flipped up?
