Thermometer Problem
Old Oct 12, 2003 | 10:05 PM
mosterka's Avatar
mosterka
Thermometer Problem
My 04 F150 temp gauge is having a probem and I was curious if anyone else is seeing the same thing. This morning, I was in the desert. It was pretty cold (50's). When I got back in the truck in the afternoon, it was nearly 100 degrees. However, the thermometer was at 50 degrees. It took about 20 minutes or so for it to sloooowly climb up to the correct temp.
Anyone else?
Thanks in advance.
Old Oct 18, 2003 | 01:43 PM
NJexpedition's Avatar
NJexpedition
Sory to hear this on the 04 150s I have a 03 Expedition and it has the same problem. Dealer says this is normal. Just another reason I will not buy another Ford product.
Old Oct 18, 2003 | 03:30 PM
Chiefman's Avatar
Chiefman
I have had a few cars with these outside temperature gauges. I also know people who have other makes with them. All outside temperature gauges do this. It takes the thermometer awhile to heat up or cool down when you turn the car on. Just part of having one of those. They are only accurate after you've been moving awhile.
Old Oct 18, 2003 | 04:10 PM
Dr No's Avatar
Dr No
Re: outside temp.problem
This is a known problem with 04 F150.
I will bet your a/c doesn't work well when
temp is acting up also.Go to your dealer,tell
service advisor of problem.If he dors not
know the fix,tell him to look up the bulletin.
It is a computer prom reflash.
Mike
Old Oct 18, 2003 | 05:44 PM
HomerWinzlow's Avatar
HomerWinzlow
It is perfectly normal and how all have worked since they have been avaliable from Ford. It will report the last recorded temp on start up and will gradually increase unless you maintain a constant speed over 35 for 3 minutes.
Old Oct 19, 2003 | 08:38 AM
mosterka's Avatar
mosterka
Mike:
Fortunately, the dealership, after a lot of convincing, decided to look further into it. They just ordered the CD to reprogram it.
This does not happen in my 03 Expedition. That leads me to believe it is not normal.
Old Oct 19, 2003 | 02:59 PM
Dr No's Avatar
Dr No
mosterka
I hang out at F150 Online sometimes.They have been following
a few problems that have come to light since more and more fo
the 04 F150 have hit the road.Since you own one of these beautiful beast,you may want to take a look at that forum.
Mike
Old Oct 20, 2003 | 09:02 PM
gbl56's Avatar
gbl56
took delivery of an '04 Lariat Friday, 10/17. Today, 10/20, the outside temp guage was stuck on 66 degrees and it was about 92 degrees outside here in So/Cal. drove for 45 minutes and it slowly worked up to 81, but never went higher. had to work a/c manually.
Old Oct 20, 2003 | 11:17 PM
Dr No's Avatar
Dr No
More info. on temp.problem.
It appears all that were produced before 10/6/2003
could possibly have this condition.Some of the larger
dealers have the c/d already.
Good luck with the repair
Mike
Old Nov 10, 2003 | 11:15 AM
Dolomite's Avatar
Dolomite
I'm having the same problem with my 04 F150 FX4. I was driving yesterday and my therm said that it was 47 outside and it was actually 75 deg outside. I drove around all afternoon and it slowly went up to around 56 deg but that's it. I haven't noticed any problems with the AC.
Old Nov 10, 2003 | 04:04 PM
ripnlip's Avatar
ripnlip
04 F150 fx4 having same problem temp stuck on 59 deg, and temp outside is 80 deg. went on a 2 hr road trip temp never moved. wheres the fix??
Old Nov 10, 2003 | 08:55 PM
Dr No's Avatar
Dr No
The fix is at your local Ford dealer.
Make an appointment for prom flash.
You can't fix it with do it yourself.
Mike
Old Nov 11, 2003 | 08:22 PM
Captain Jim's Avatar
Captain Jim
I just took delivery on a 04 lariat Crew and am curious. Am I seeing that there is a connection between the engine temp. gauge and the outside temp. indicator that can affect A/C operation?
JJ
Old Nov 11, 2003 | 10:48 PM
gbl56's Avatar
gbl56
thermometer problem
Took the Lariat to have the PCM re-programmed to correct thermometer problem. So far so good.
Old Nov 12, 2003 | 05:47 AM
Dr No's Avatar
Dr No
Captain Jim
The engine temp. is not affected.
It only has to do with the outside temp.
If the outside temp.is not correct the a/c
compressor will not turn on in auto mode.
Mike
