4R100 Fluid Level Question
Old Jan 15, 2020 | 06:48 PM
Mearntain's Avatar
Mearntain
I've got an 01 4x4 with a 4R100. Tranny nearly left me stranded and I realized after getting home my cooler line completely broke almost 360 degrees around the tube where it connects to the hose on the passenger side - I have no clue how much I lost. I know I dripped atleast a quart in the drip pan after i got back home.
Basically the truck wouldnt engage in reverse at all, it just revved up, and barely got in back in forward gear to limp her the 1 mile back home. What I'm trying to figure out, is at what point the trans fluid is normally at to cause engagement issues? As in typically 2 qts low? 3 qts low? Etc? Hopefully someone will know this and it would be a huge help if so to save an extra trip to the store.
Trying to use this as a gauge to know approx how much to start with pouring in and buying extra fluid if needed. Planning on draining the pain too before filling so I'm planning on 7 qts there and I've currently got a total of 10 qts.
Old Jan 15, 2020 | 11:32 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'd just drain it completely and add all new. Here's a good writeup on the procedure.
You can dump the old fluid in your fuel tank. UNLESS you are in a rural or ag area where they commonly check diesel trucks for red dye. Big fine for using non-taxed fuel on the road.
Old Jan 15, 2020 | 11:36 PM
timmyboy76's Avatar
timmyboy76
Low trans fluid will cause it to act weird. Get the fluid back to the hash marks and go from there
Old Jan 16, 2020 | 05:06 AM
Mearntain's Avatar
Mearntain
Sounds good, thanks for that.
Old Jan 16, 2020 | 11:06 AM
Mearntain's Avatar
Mearntain
To anyone else wondering the same question as me - the answer is it has to be low as crap to have trans engagement issues.
I drained the pain and only 3.5 qts or so came out from there instead of the expected 6.5/7 qts. Added 11 qts back in and still not reading on the dipstick yet, but it will go in gear now.
On the way to get more fluid now.
Old Jan 16, 2020 | 02:24 PM
Brian Hanks's Avatar
Brian Hanks
Here is a quick link to capacities FYI.
https://www.amsoil.com/mygarage/PRNo...x?unitid=16478
Old Jan 16, 2020 | 02:39 PM
Mearntain's Avatar
Mearntain
Thanks for that, that's a nice reference to have. Originally, I was more just curious as to how low the fluid needs to get to start having issues with engaging in gear. I had no clue how much I lost so was trying to guesstimate how much more I would need.
TheHungryTubist
Mar 12, 2019 05:14 PM
dan8052
Aug 16, 2013 01:23 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 11, 2008 08:38 AM
arizonius
1978 - 1996 Big Bronco
Jan 25, 2004 12:09 AM
state
Sep 8, 2003 01:16 PM
