1977 f150 trans mounting problem
Old Jan 13, 2020 | 05:41 PM
Aaronb12's Avatar
Aaronb12
Hello I have a 1977 f-150 that I’m currently 460 swapping. Problem is I bought I 2wd trans instead of the original 4wd will this work? Anyone have a picture of how the trans mounts up to the crossmember? Thanks in advanced
Old Jan 13, 2020 | 06:13 PM
440 sixpack's Avatar
440 sixpack
I assume you're putting it back in a 4x4, you're going to have mount the transfer case in place of the tail housing and the mount goes on the transfer case.
Old Jan 13, 2020 | 10:21 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
???? WHAT You cant do that the tail shaft needs changed. To do this the whole case needs gutted, but unless you have the right tail housing and shaft, it still won't work. the cross member mounts on the tail housing of the trans and the frame bolts up the transfer case. I am afraid you are up $(-)1T creek with a broken paddle.
Old Jan 13, 2020 | 10:24 PM
broktruk's Avatar
broktruk
What trans did you take out?
F-250 Warhorse could probably point you in the direction of an output shaft and adapter.
Jason Mascari
May 4, 2017 03:10 PM
02325
Mar 31, 2012 03:50 PM
RossOlson
Jun 22, 2010 12:17 PM
busterhd
May 9, 2001 06:55 AM
Katt
Nov 10, 1999 07:17 PM
