No crank/no start, no dash lights, interior and exterior lights. Also NO POWER TO #23 FUSE
My 01 expedition will not start no crank plus when my husband that is a mechanic check the fuse box he said he wasnt getting any power to the fuse number 23 with the rest light. With ignition on or with it off. I need help please
I was told that I had a 04-07 f150 trition 5.4L, we figured that much out with the serpentine belt diagram, is there anyway that you could tell me hpw to fine the engines serial number so that I can try to figure out what size motor I got in this thing. And figure out how to get it running again.
Any '04 to '07 model year 5.4L equipped F-150 is a 3-valve engine, and will not be compatible with your 2001 Expedition. I don't quite understand your last question. Are you asking for the physical location on the engine block itself for the engine serial number, or are you asking how to identify the engine that your truck is equipped with, when you just stated in your initial post that you have a 2001 Expedition equipped with the 5.4L V8?
Yes I understand that is what I stated, I bought this vehicle for a so called car lot. The body is a 01 we was told that the engine was out of a 05-07 f150 but it was still a triton v8 engine 5.4L. And yes I wanted to know where to look to get the engines serial number where I can look for it and try to figure out why type and year the motor is in my car. And plus, can you tell me the symptoms of how the car will act while running and driving with this motor in it if its the wrong motor.
It ran up until right before Christmas
we never drove it because of this:
bucking, jerking, misfiring the codes that it threw was misfiring and running lean on bank 1 also was throwing a code for the TCC (transmission clutch converter) I also found a couple wires that were burnt that was sitting on the exhaust that ran to the neutral safety switch, i pulled all the wires and checked them and tapped them wires up (4R100 transmission) that is the original transmission that came in the 01 expedition eddie Bauer 4x4, now i was told that it had between a 05-07 f150 2 wheel drive (also noticed the oils drain plug is blocked by part of the frame, so can't change oil buy the plug)
ExcursionBoy1984
02-02-2010 10:50 PM
blackestate
11-20-2008 02:20 PM
jlande
04-27-2007 11:00 PM
