2019 - 2023 Ranger Everything about the new 2019-2023 Ford Ranger.
Auto Start/Stop
Old Jan 13, 2020 | 08:38 AM
mbell5263's Avatar
mbell5263
Auto Start/Stop
Does anyone know why Ford has a way to temporarily disable the auto start/stop both via a button and using the settings in the dash? Initially, I figured that the button was just for your current trip, which it is, but the settings in display would disable it until turned back on...but that is not the case. No matter which way you disable it, as soon as you shut your vehicle off and restart it, you have to disable it again. It makes no sense.
Old Jan 13, 2020 | 09:52 AM
johnday's Avatar
johnday
I have this on my 150, maybe email them, or call, and see if they have anything in the works for the Ranger.
https://www.cjponyparts.com/autostop...-2019/p/AE001/
There is another company out there that has a device that plugs into your OBDII port.
There are other ways known on the 150 to defeat this thing, maybe they'd work on the Ranger as well, just do a search.
Old Jan 13, 2020 | 11:05 AM
reddog99's Avatar
reddog99
You can put the tranny in "Sport". The auto start/stop isn't active there.
I didn't like the feature at first, but that four-banger isn't a smooth engine when at idle, so I have come to like it when in traffic.
Old Jan 13, 2020 | 11:50 AM
WXboy's Avatar
WXboy
I assume that the deal was in order for the EPA to allow them to use ESS during certification, Ford had to prove that the feature would be incorporated into the standard driving mode, i.e. it's in operation every time you start the vehicle.
We're lucky we have buttons, for now, that allow it to be shut off.
Old Jan 13, 2020 | 02:09 PM
jschira's Avatar
jschira
I have read that the auto start/stop does not work when a trailer is hooked up. Some people cut the wires off of a 4 prong trailer plug and then plug the dummy plug into the truck.
Old Jan 13, 2020 | 03:28 PM
F250Wheels's Avatar
F250Wheels
Mine so smooth I can't tell it's running, unless I look at the tach.
Old Jan 13, 2020 | 03:30 PM
F250Wheels's Avatar
F250Wheels
I tryed the trailer plug, and the screen starts asking questions about trailer, and the lane control is disabled.
Old Jan 14, 2020 | 12:46 PM
jhgr's Avatar
jhgr
Buy a cheap night light and plug it in the 12 volt receptacle on back of console. problem solved
Old Jan 18, 2020 | 11:42 AM
1986F-150's Avatar
1986F-150
What 12 volt receptacle?
One of the USB ?
Is that a Lariat thing?
I have a 110 volt household plug in on my XLT but it is AC .
Old Jan 18, 2020 | 01:41 PM
jhgr's Avatar
jhgr
You are correct it is a 110 volt household plug in on back side of console. have to be in back seat to see it.
Old Jan 18, 2020 | 03:33 PM
1986F-150's Avatar
1986F-150
So you plug a night light into that and it turns off Stop/Start ?
Old Jan 18, 2020 | 03:56 PM
jhgr's Avatar
jhgr
Just plug it in and forget about it. Only time it is on is when your truck is running.
Old Jan 19, 2020 | 10:43 AM
reddog99's Avatar
reddog99
It sounds like you're saying to plug a 12 v. light into the 110 v. socket. That won't work out well...
Old Jan 19, 2020 | 03:41 PM
1986F-150's Avatar
1986F-150
nobody said that
Old Jan 19, 2020 | 03:45 PM
1986F-150's Avatar
1986F-150
What is this supposed to do? I don't get what you are trying to say?
You are claiming a nightlight will make the Start/Stop feature from working?
