Funny dealer experience, mostly positive
Old Jan 10, 2020 | 08:48 AM
98ramtough's Avatar
98ramtough
Took my truck in the other day to get a few things done.
1) New wheels and valvestems due to leaking air.
2) Drivers battery leaking
3) rattle in passenger door, foam kit installed to stop rattle
4) tailgate recall performed
5) Whatever the carpet recall crap was
6) Asked them not to perform the LED headlight recall, but they did it.
When I went to pick the truck up the air pressure on all 6 tires read 90-93PSI. Figured maybe the sensors were not reporting accurate yet so got out and checked one manually. Sure enough over 90 psi. I went back into the service office and asked why they would air up 90psi on all 6 tires when the tires are rated for 80 and should be 70-75 front and 65 rear. They called the tech on his lunch break and had him on speaker phone and he says he always airs duallys up to 90. Wonder how many other guys are driving around rattling their teeth with over inflated tires from this tech. Wasn't a big deal, easy enough to air them down and set them correctly. They left white chalk all over the tires and didnt clean the new wheels. They only replaced one of the two batteries. I'll just run them till they leak again or swap them out for interstates soon. I had been somewhat satisfied with the few trips to the dealer service. Trips like this makes it hard to leave a glowing review. I'm sure it depends on the dealer, but my experience with RAM trucks service has been a lot better than Ford. The little air pressure deal makes me nervous to have them perform oil or fuel filter changes. Usually do all that myself and will continue to do that. Hopefully this is the last trip to dealer for a while.
Old Jan 10, 2020 | 08:58 AM
C12H24's Avatar
C12H24
Attention to detail is what makes the difference. Not just automotive service, but EVERYTHING. This very minor oversight has left an impression on you, leaving you to question if you can trust this business to perform competently.
Old Jan 10, 2020 | 10:07 AM
hobbie1's Avatar
hobbie1
I can tell stories about 2500 RAM's that will make your hair standup on the back of your neck....
I had 2 a 12 that was bought back and a 14 that was in the shop even other month. When I got rid of it I had a 2" thick stack of repair orders.
Old Jan 10, 2020 | 10:14 AM
ForCal's Avatar
ForCal
Like you said, it depends on the dealer, and more specifically their staff. Things like that are why so many hate going to the dealer. To be fair, I find a general lack of caring throughout the industry, dealer or not.
I'm interested in that door rattle fix and the foam kit. Do you have any more details on that?
Old Jan 10, 2020 | 11:13 AM
seville009's Avatar
seville009
I always check my tire pressures after I get tire work done.
have never had them over inflated, but I have received them with about 35 psi in them (load E 18” tires - usually have them at 72 psi)
Old Jan 10, 2020 | 11:26 AM
1dryfly's Avatar
1dryfly
So far I’m not impressed with simple services I’ve had done at 2 differant Ford dealers. One issue was when I had the tires roatated. One lugnut did not have the washer installed and the lugnut was not torqued to spec. The second issue was a leaky oil filter after the dealer did a oil change. This kind of problems should not happen. I guess I’ll keep trying to find another dealer to do these simple services.
Old Jan 10, 2020 | 01:00 PM
whagen's Avatar
whagen
I bring a torque wrench whenever i have wheels taken off and do the final torquing if possible myself.
But I can't say I have been ever been satisfied with the quality of work or service from a dealership (maybe once or twice I have) (multiple fords, chevy's, GMC or Cadillac). Independent mechanics I have found some not so good one's but in general better they are better than dealership mechanics. If the warranty repairs could be done at an independant place I think I would have it done there even if i had to pay labor sometimes. I am sure there are plenty of good mechanics working in dealerships, it's just disappointing to see such poor quality work being done.
I have had all the following happen:
  • brake lines rerouted on the wrong side of a heat shield after an engine replacement
  • pinch welds bent over and flatten from jacking up on them (ended up pushing the bottom of the fender out)
  • Aluminum control arm broken from hammering on it to remove a ball joint. Cracked the control arm so the ball joint flopped around and didn't stay seated
  • brake backing plates mangled trying to get off rotors (to lazy or dumb to turn the adjuster in)
  • broken wire harness when replacing an alternator, also broke a bracket used to restrain harness (it was ready to fall into the fan)
  • missing hardware or loose hardware.
Old Jan 10, 2020 | 04:13 PM
98ramtough's Avatar
98ramtough
You guys are right, I'm sure it just depends on the dealer. As far as the "foam kit" I told them there was a bad rattle especially when cold coming from the passenger door by the mirror and they said its common and have a foam kit to fix it. I read about it on this site bit figured I'd ask them about it. On the paper it just says foam kit for the fix. It seems to have fixed the rattle.
now_exowner
6.7L Power Stroke Diesel
Feb 2, 2014 07:05 PM
EpicCowlick
60
Feb 9, 2011 02:59 AM
ronjeremy6
Jun 5, 2008 10:47 AM
xlt4me
Car/truck Buying Advice
Jun 8, 2004 04:04 PM
Debby
Jan 14, 2002 01:09 PM
