2017 6.7 ATF question
Old Jul 16, 2024 | 01:47 PM
philips's Avatar
philips
When I change ATF fluid, I measure fluid level on dipstick beforehand as specified and record that level (full, halfway, etc.). When I drop the trans pan I collect all the fluid in the drain pan. I pour the drain pan in a one gallon container that is marked with divisions of quarts and ounces. The amount that comes out is the new amount that goes in, this provides a pretty good base starting point.
Old Jul 16, 2024 | 07:34 PM
johndeaux22's Avatar
johndeaux22
My 2017 F350 6.7 4x4 DRW gets a pan drop and filter every 60-65k miles. I use a valveoline ATF that meets MERCON LV spec, truck has around 225k miles and has spent most of its life with around 20k trailer hooked to it. Still shifts and drives great. It typically takes around 10qts just draining the pan and changing filter. I pour into a three gallon paint mixing bucket with level marks, then refill with what came out
Old Jul 16, 2024 | 08:56 PM
pottman's Avatar
pottman
7th Gear
Just did a drain and fill w/filter change at 60k.
This is the reading on my dipstick after adding 8.5 quarts and reaching operating temp 196* and cycle through gears. Just want a 2nd+ opinion on the measurement.
Old Jul 17, 2024 | 11:14 AM
WXboy's Avatar
WXboy
That's pretty much what I had. I added 9 quarts. I drove the truck to a more level spot, cycled the trans through the gears slowly, then checked again and it was at the top of the hatched zone so I left mine alone.
Interestingly, when I pulled the drain plug and drained the pan, then reinsert plug and refill it only took 6 quarts. So the filter and the shape of the pan hold 3 quarts? Wow.
4x4fordtrkn
2004 - 2008 F150
20
Aug 21, 2015 09:00 AM
Firefighter 1406
Aug 5, 2014 04:20 PM
Crewcab Turbo
Apr 12, 2013 01:15 PM
kevin.ford-trucks
Jun 16, 2012 01:31 PM
mwielgosz
Oil & Lubrication
13
Feb 24, 2007 11:21 PM
