...first off, long time reader, first time poster. Have learned much from many of you for new ride, and would like to have some confirmation before I order the parts this week. I have a 03` 250 w/5.4, Not my first motor choice, but left over prices are too good to resist. Truck is a supercab longbed 4x4. Looking to level, and fit 33x12.516's under it.
Looking at the:
- FABTECH 3.5 spring hanger
- F-350 Rear Blocks
What I need help on is which shocks do I use ? I know the Bilstein's are highly recommended, or should I stay with what fabtech's complete comes with? will they be the right length?
I do have the BE5-6245-H5, BE5-6246-H5 part numbers for the SD specified shock, but not sure if this shock will work with this leveling set-up ??
I used a different brand level kit using the shackles. If you can order just a set of shackles without shocks, this is the best option. If not any shock besides stock is better.
Bilsteins are worth the extra cost. Spend a little extra now or a lot more later.
