Using load rated E tires on 2012 F150
Old Jan 6, 2020 | 01:57 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
We are buying a 12 F150 crew cab 5.0 4x4. My dad has a set of snow tires from his crashed 05 superduty. I believe the SD tires are the same size. Anyone run load rated E tires on a F150? I would guess the ride would be a little more harsh but more responsive due to stiffer sidewalls.
Thank you
Old Jan 6, 2020 | 02:05 PM
cb_13's Avatar
cb_13
I run 275/70r18 load range E tires on my 12 super crew. You will have a slightly stiffer ride and slightly less fuel mileage due to weight of the tire. Also to meet the same load carrying capacity as a P tire at 35 psi you may need to run 40 or 45 psi. Toyo actually has a chart on their website explaining that.
Old Jan 6, 2020 | 02:15 PM
seventyseven250's Avatar
seventyseven250
Worse fuel economy, rougher ride. Might handle loads better. I've done it, it's fine. If you are getting good tires for free, it's fine.
Old Jan 6, 2020 | 04:10 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I didn’t consider the heavier weight of a load E tire. How noticeable was the mpg drop? Winter will be hard to tell as there is more idling to warm up.
Tires won’t be free. Haven’t asked him yet. Has all seasons on it currently that I’m pretty sure my wife won’t go with.
Old Jan 6, 2020 | 07:43 PM
ck1404's Avatar
ck1404
Good question. The 10 ply tires are tough and needed if you drive off-pavement on bad roads. And recommended by Ford to be 55 psi based on recent door sticker. That is on a 2019 F-150 FX4 that came original equipment with LT 10 ply tires. That 55 psi setting is rough and I try to keep TPS happy at 48 psi.
We have run 10 ply tires on a 2007 F-150 4x4 forever now with factory TPS setting at 35 psi. It has about 170,000 miles on it. We run those tires on this truck at about 44 psi and the ride quality is good enough. And they wear well. If you go to this level of tire, would suggest doing at least 40 psi. The ride will be rougher, the tires are heavier and probably matter some with mpg.
Old Jan 6, 2020 | 07:51 PM
seventyseven250
A family member runs a large fleet of trucks and he says it's 1-2 mpg drop in mixed driving. Now, there's a lot of variables, but that sounds reasonable to me.
Old Jan 7, 2020 | 09:35 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
That's something I didn't think about either is the TPS. Will it set off running higher psi or just when it drops to some set point below 35psi?
Old Jan 7, 2020 | 06:25 PM
ck1404's Avatar
ck1404
The TPS is based on factory setting which is on the plate in the driver's door. If it says 35psi and that is likely, then you should be fine running higher.
Old Jan 8, 2020 | 10:23 PM
Goldstar225's Avatar
Goldstar225
Trailering
I've been running the BFG AT KO2 load range E tires on my F150 SC. Dropped about 2 MPG from the factory tires. Rides a little rougher. I have 55,000 miles on them and I've ran 35 PSI the entire time (except when towing my camper). Tread wear is even all the way across the tread. By their looks I should get another 15,000 miles before I hit the wear bars.
Old Jan 9, 2020 | 06:18 AM
Atlee's Avatar
Atlee
My truck, which came with the HDPP, had OEM LT245/75R17 LRE tires on it. They were BF Goodrich Rugged Trail AT's. Finally replaced them with the more robust tread design BF Goodrich A/T LT245/75R17 LRE tires. No clue how much harder they ride since I've never had anything else on the truck. The tire pressure Ford recommended on the yellow sticker on the door frame is 55# front and 60# rear.
Old Jan 9, 2020 | 11:00 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I would suspect some of the mpg drop is due to the more aggressive tread design creating more friction with the road.
07EXPYEL
35
Oct 19, 2020 08:37 AM
fordtruckowner
2004 - 2008 F150
41
Dec 3, 2007 11:24 PM
Ultraute
Sep 9, 2004 08:30 AM
Bolliger
Jan 23, 2004 04:15 PM
tasmith
Feb 6, 2002 01:25 PM
