change over to led.
Old Jan 6, 2020 | 01:13 PM
grumpyinme.'s Avatar
grumpyinme.
change over to led.
On my 1994 f250,7.5,e40d 4x4 will changing over to led lighting effect anything,I have already changed over the flasher.
Old Jan 6, 2020 | 02:41 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
I tried LED turn signals and brake lights without modding the wiring or flashers and my truck also has the E4OD and the torque converter would not lock up. Put regular bulbs back in and it worked. If you try LEDs you likely would have to add in line resistors to mimic a regular light bulb to keep things working like stock.
Old Jan 6, 2020 | 05:26 PM
EQCMCAT's Avatar
EQCMCAT
Same issue I experienced. I even tried LED bulbs in the third brake light and they prevented over drive from engaging. Went back to OEM incandescent bulbs and now my 95 F-150, 5.0 W/E4OD shifts like it's supposed to. I wanted to reduce the heat build up in the brake light sockets, especially the third brake light, as I've seen too many become deformed / melted on trucks in the junk yard. So what I ended up doing, went with the lower wattage smaller bulb bulb in the third brake light, the bulb used in the instrument cluster. They burn cooler and haven't had any determent on transmission shifting into overdrive. Ya, they burn dimmer, but they still illuminate when I hit the brake. I've been so conscious of the heat build up melting the brake bulb sockets, that I put the truck in neutral waiting for a red light.
Old Jan 6, 2020 | 06:00 PM
Air Cooled Nut's Avatar
Air Cooled Nut
LED bulbs in the rear of my '90 made the cruise-control inoperative Of course I didn't read about that here until after I bought and installed them. Now I'm back with the regular incandescent bulbs Since polishing my headlamps was so effective I'm gonna do my tails so the lenses will be like new.
I put LED bulbs in my turn signal indicators in the dash and that actually made a big difference in my seeing them, however, it did seem like a lot of work for just two bulbs
Overall, I think the LED swap is a good idea. Just make sure the LED color matches the color of the lens it will be shining through i.e. red LED for red filter/lens, clear LED for clear filter/lens, green LED for green filter/lens, etc.
Old Jan 6, 2020 | 10:47 PM
saguaro_squeezer's Avatar
saguaro_squeezer
So, do the kits with the resistors make a difference? I'd love LEDs in the taillights but just put in the cruise and don't want to render it inop.
Old Jan 7, 2020 | 09:34 AM
Da_Lariat_Chariot
Haven't tried it personally, I just bought new lenses that look good for the rear and restored the fronts for better visibility. But in theory, if you get the resistance correct to what a regular bulb is, it should work.
Old Jan 7, 2020 | 07:17 PM
TexasGuy001's Avatar
TexasGuy001
I think there are issues with changing the CEL and Battery indicator to LED.
Of the 3 brake lights 1 needs a resistor for the transmission to be happy.
Old Jan 8, 2020 | 07:58 AM
Air Cooled Nut
I don't know for sure, however, I don't think so. With an incandescent bulb electricity can still flow through it but at a lower amount -- a trickle if you will -- that won't be enough to actually light the bulb. A LED is more like a switch, ON or OFF, and when OFF no electricity flows through it.
Old Jan 8, 2020 | 09:07 AM
grumpyinme.
Hi,Well I guess I asked a good question,and after reading all your comments ,I think I will god with he new lights on rear and polish the fronts.Thanks for all the help, interesting to hear what everybody says.sounds like the lens will be the less troublesome,damn comuters.ty
Old Jan 12, 2020 | 06:29 PM
Wheelman55's Avatar
Wheelman55
In my ‘93 F250 E4OD, I put led’s in all sockets in the cluster, dashboard, interior light, door lights. No performance issues and a nice bright cluster and dash.
https://www.ford-trucks.com/forums/1...l#post16502191
Old Jan 12, 2020 | 08:30 PM
torq'ta 5 8's Avatar
torq'ta 5 8
can/have you tried to dim them any, and would they dim or go out
Old Jan 12, 2020 | 10:20 PM
Wheelman55's Avatar
Wheelman55
They dim just fine with the headlight dimmer.
Old Jan 13, 2020 | 12:52 AM
Jonathan White's Avatar
Jonathan White
[QUOTE=Wheelman55;19053215] if you figure out the resistance valve of one bulb you may be able to put in a resistor of the same value to compensate in the blinkers and taillights I am gonna swap over to LEDs I'll report back
Old Jan 13, 2020 | 07:02 PM
torq'ta 5 8
the reverse light(3156) is 26,88 watts, and ohms law says resistance is 5.35 ohms, - I changed to LED no resistor did not effect trans shifting
the rear brake light (3157) is 27 watts, and ohms law says resistance is 5.33 ohms,
the 3rd brake light(921) is 17.92 watts, resistance is 8.05 ohms
ohms law- watts divided by volts = amps, then volts divided by amps = resistance
LongRider
General Automotive Discussion
Oct 31, 2019 11:59 PM
rowekmr
Jul 6, 2019 09:18 AM
Diesel 724
Mar 10, 2011 06:45 PM
Rusty_S
Jan 13, 2010 07:50 PM
88iroc
Mar 24, 2003 09:49 PM
