289 cylinder compression
Old Oct 12, 2003 | 02:37 PM
tweakingit's Avatar
tweakingit
I have a freshly build 289 and was wondering if the PSI on the cylinders of 60-100 PSI is enough to cause a problem. If so how is it fixed? I tried a little oil in the cylinders and that gave me the max presser of 60-100 PSI. Before the oil some cylinders had hardly any PSI I mean about 10-15psi.
Old Oct 12, 2003 | 02:48 PM
90f150moneypit's Avatar
90f150moneypit
This is a fresh build??
Did you build it or someone else? The reason I ask is it's easier to ask the right questions.
Old Oct 12, 2003 | 04:54 PM
tweakingit's Avatar
tweakingit
I did the rebuild but what would that have to do with the compression?
Old Oct 12, 2003 | 07:56 PM
90f150moneypit
The reason asked=you know what is in the motor.
Are the rings file fit or standard rings? Were they checked anyway? Sometimes the standard sets can be gapped way too much from the factory. If they were file fit, what were they gapped to?
New pistons or reused originals?
If new, are they the correct size for the bore? I've seen and heard of accidently using a .010 over piston in a .030 over bore.
Also could have been honed too much for proper fit.
Was the ring gap spacing correct?
Just some idea's
Old Oct 12, 2003 | 08:48 PM
circledirt's Avatar
circledirt
If I remember right, 289 valve have to be set much like a chev(hurt my fingers typin that last word). Valve lash set too tight?
Old Oct 13, 2003 | 01:54 AM
200000+F150's Avatar
200000+F150
Valve lash sounds right. Back off rockers a little and see if it comes up.
Old Oct 13, 2003 | 07:57 AM
jwtaylor's Avatar
jwtaylor
Everyone offered great questions and/or solutions but not an answer to your question. Your compression is very very bad for a fresh rebuild. Have any of the suggestions helped out? Later
Old Oct 13, 2003 | 10:24 AM
tweakingit's Avatar
tweakingit
No nothing is helping i still haven’t taken the block back out of the car yet to check the rings. The motor did start once and ran for about 30min total then I drove it the next day for about one block. Then it died and hasn’t started since would Excessive fuel in the cylinders keep the compression down. I also fount a lot of fuel in the oil. Which I have changed. And I put oil in each of the cylinders. I tried to start it again it tried to start twice. Or I mean that one or two of the cylinders fired then nothing again just turning over and over. It has a new carb on it and I think maybe it’s feeding to much fuel to the motor. And washing out the cylinders.
Old Oct 13, 2003 | 10:25 AM
tweakingit's Avatar
tweakingit
The rockers are not adjustable.
Old Oct 13, 2003 | 11:01 AM
stepman's Avatar
stepman
I'd have to go back and look at the valve timing. Your rings are probably not seated yet and will leak some but, even with the ring problem, you should be able to get well over 100psi of compression.
Old Oct 13, 2003 | 10:49 PM
DW2455's Avatar
DW2455
did you stagger the ring gaps before you put the pistons in? you definatly have a problem. is the cam , push rods stock? DW
trekbasso
17
Jan 11, 2015 08:18 PM
Outlaw56
Oct 11, 2013 11:38 AM
Lenster
Oct 13, 2010 03:41 PM
wildwest
Feb 1, 2005 10:47 PM
macman85602
Dec 7, 2003 10:57 PM
