First off thanks for the add. My '67 f250 w/352 has been acting weird, engine was running fine one day then the next it was running rough, had to give it a lot of gas to keep it running. I shut it off for about an hour, turned it on again & it ran fine, The next day I turned it on & again running like crap. Sprayed off the carb, checked the wires everything looked good. I was thinking maybe bad gas? Anybody have an idea of what it could be??
You will need to take your question to the Older, Classic &Antique Truck section, or even the Performance, Engine Troubleshooting section to get the needed response(s). Pictures, even if it's just the engine compartment, are always appreciated.
