Charging system
Old Jan 1, 2020 | 06:37 PM
gnoon's Avatar
gnoon
Charging system
97 F350 diesel. I have my instrument cluster pulled for repair. I'm only getting 12.5v at the batteries. Is this a result of the instrument cluster being out of the truck?
Old Jan 3, 2020 | 09:15 AM
knottyrope's Avatar
knottyrope
the alt has a built in regulator but isnt turned on until the exciter is energized
no sure if the cluster affects this with the voltage gauge
Old Jan 3, 2020 | 07:05 PM
farmert's Avatar
farmert
The battery light in the dash is part of the exciter circuit, if I'm not mistaken. There was a thread years ago about the alternator not "turning on" if the bulb was burned out.
Old Jan 3, 2020 | 11:37 PM
Hit Man X's Avatar
Hit Man X
My 1996 EVTM shows a resistor in cluster at that battery symbol. It 'should' still charge with the bulb burned out...if not, replace it.
Also check that green wire into voltage regulator for 12V with key on engine on or off. Yellow should be constant hot and that white guy from regulator to stator is what excites it to turn out...like a good looking woman. Haha
Anyway, keep us posted. Simple circuit.
Firefighter437
May 22, 2016 10:13 PM
mattg529
1997 - 2003 F150
Feb 3, 2013 07:36 PM
bart f-350
Electrical Systems/Wiring
May 8, 2009 08:51 AM
