Sponsored by: Real Truck
E-brake cable F550, no adjustment!
Old Jan 1, 2020 | 12:12 PM
RenoHuskerDu's Avatar
RenoHuskerDu
Checked out the E-brake cable on my E99 F550 yesterday, 60" Cab2Axle. Surprised that the cable offers no adjustment, and it hangs slack a lot. @calvinhg wrenches all day and has seen some with, many without. I wonder why Furd chose to save a buck this way. A threaded end on the main cable couldn't have cost more than a dollar in bulk purchase. Oh well.
Guess we'll jury rig up a cable clamp at the T to remove the excessive slack. There must be some adjustment possible on the little drums too.
Old Jan 1, 2020 | 12:45 PM
Just Strokin's Avatar
Just Strokin
There is a process to release the tension on the cable so it can be removed on later models. This is done on the parking brake/E-brake mehanism in the cab. I would check the parking brake/E-brake mechanics in the cab to see if there is a problem with it.
Maybe someone has the procedure/photos they can share.
Old Jan 1, 2020 | 06:35 PM
RenoHuskerDu
There is enough slack in there to just pull off the cables at the T back near the LR tire. Perhaps that tension release happened. I did look at the pedal mechanism and saw nothing in the way of adjustment. I'll look again but this time see if there's a tension release mechanism. Thanks.
Old Jan 1, 2020 | 06:39 PM
Dan V's Avatar
Dan V
@TooManyToys. ..pretty sure he can solve this.
Old Jan 1, 2020 | 09:29 PM
SnowPlowDriver's Avatar
SnowPlowDriver
Check the backing plates to see if the hold down pins have fallen inside the drum..
Old Jan 1, 2020 | 10:45 PM
RenoHuskerDu
Pulling the toolbox bed off as soon as it passes state safety inspection. Then I'll have a chassis cab for a while, which will allow easy access to much.
Adding that to the list to check when it's just a frame back there.
aapropane
Nov 13, 2017 10:49 AM
BPofMD
Maryland Chapter
Sep 17, 2017 10:19 AM
ac700wildcat
Mar 5, 2007 10:41 PM
