Key on hot
Old Dec 31, 2019 | 12:56 PM
Snowman 8's Avatar
Snowman 8
Key on hot
We just traded our 2016 F150 for a 2019. I took my air bags off the 16 to install on the 19. On the 16 I just had the power supply wire for the on board compressor hooked to the battery. I would like to hook it to a wire that is only hot in run this time around. Has anyone found an easily accessible wire to tap into for 12 volt hot only in run?
Old Dec 31, 2019 | 10:24 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I wouldn't put that on an existing ignition-on circuit. I'd put on a relay controlled circuit connected to the battery.
Old Jan 1, 2020 | 07:50 AM
Snowman 8's Avatar
Snowman 8
I am looking for an un-used wire that is hot while the truck is running like on the super duty trucks. I wouldn’t just splice into any old ignition wire... I don’t know why Ford doesn’t offer upfitter switches in the F150’s. They share the same cab as the super duty’s so why Ford wouldn’t make upfitter switches available as an option in the F150 is beyond me.
Old Jan 1, 2020 | 04:14 PM
CathedralCub
FTE Community Team
Probably to save a few bucks on the 90% that never see electrical add-ons.
Old Jan 1, 2020 | 07:33 PM
Snowman 8's Avatar
Snowman 8
That’s why I said to at least offer it as an option. To pay for if some wants it... like the multiple posts on here asking how to add upfitter switches to an F150. It costs way more to do it later.
Old Jan 1, 2020 | 07:44 PM
ford390gashog's Avatar
ford390gashog
Fuse 22 or 27 will work to trigger a relay. Don't attempt to run the compressor off any circuits without a relay that feeds from the battery. All the higher amperage circuits are taken in the SJB.
Old Jan 1, 2020 | 07:46 PM
Snowman 8's Avatar
Snowman 8
Thank you. I will look into those
montauk1
Jul 24, 2016 01:20 AM
fishwitch
Nov 21, 2010 10:27 PM
pyro2nite
Jul 15, 2008 11:37 AM
F150LariatGuy
Electrical Systems/Wiring
Mar 27, 2007 01:53 PM
4wheelFordfan
Oct 20, 2005 08:07 PM
