Sponsored by: Real Truck
installing air compressor, can't find ignition-only wire
Old Nov 21, 2010 | 11:29 AM
fishwitch's Avatar
fishwitch
how do I find a wire that is only hot when the ignition is on?
I am installing an air compressor for the air bags. I need to find an ignition-only wire to power it. I've tried the cigarette lighters but they are hot with the ignition off. 2004 F-350 6.0L DRW
Old Nov 21, 2010 | 10:08 PM
c.f.moore's Avatar
c.f.moore
Depending on the size of the compressor, it may be easier and safer to run straight to the battery. Fuse the line, install a solenoid, with a toggle switch.
Goodluck
Old Nov 21, 2010 | 10:27 PM
brd7666's Avatar
brd7666
I don't know if your year truck is different, but I have an 01. In my fingertips, in the pic is my ignition on hot wire. It is with my pass through wires. You can see the red, blue, white, and black pass through wires. Mine were under the dash just above the hump in the middle. The ignition on hot wire had the heat shrink on it, and the pass through wires did not. I hope this helps. Here is a pic.
Ridin'High
Nov 7, 2012 10:28 PM
lindb40530
Jan 16, 2010 11:15 PM
Dieseldan7.3
Dec 27, 2005 06:55 PM
the wood
May 23, 2005 04:33 AM
