2020 Front Coil Spring Codes
Old Feb 12, 2022 | 01:20 PM
  #61
dzdiggin'dude's Avatar
dzdiggin'dude
Is your truck a diesel? Did you change your bushings?
Old Feb 12, 2022 | 02:00 PM
  #62
JAKE65MM's Avatar
JAKE65MM
Originally Posted by Brandon12686
Yep, I installed them (LAV) on my truck.
According to the info above LAV are tremor 4800 lb springs.
Old Feb 12, 2022 | 03:45 PM
  #63
Brandon12686's Avatar
Brandon12686
Sorry, replaced the stock with LAS.
Its a 2022 F-350 diesel BTW. Came with 5200 springs. Stock bushings and no issues.
Old Feb 12, 2022 | 04:06 PM
  #64
JAKE65MM's Avatar
JAKE65MM
Perfect that's exactly what I wanted to know, thank you.
Old Feb 15, 2022 | 10:44 PM
  #65
number9xd's Avatar
number9xd
Originally Posted by 4wd6.7L
The front GAWR on your sticker is an indication of what springs you have.
The heavy service bumped your springs up to the 5990. It would have come with 5600's.
I ordered my truck (‘22 F250, 7.3) with Heavy Service Front Suspension in hopes it would bump me to 5600# springs. Would have got Snow Plow Prep, but it made me add heavier alternator and dual batteries. The HSFS was much cheaper way to just get the springs. Hopefully it will get here mid-April and I’ll find out if the plan worked. (hope it didn’t give me 5990 springs).
Old Feb 15, 2022 | 11:11 PM
  #66
4wd6.7L's Avatar
4wd6.7L
I wouldn't expect that you would get the 5990 springs on the 7.3l F-250 w/HSFS, might not even get 5600. If it was a deisel 350, then yes. Not sure what a 7.3l 250 comes with standard, but the HSFS says it's a 1-up spring rate upgrade. My 6.7l 250 came with 5200 springs, I guess that would mean I would have 5600 springs if I had the HSFS package.
Old Feb 16, 2022 | 07:00 AM
  #67
number9xd's Avatar
number9xd
From what I understand from the 2022 Camper and Loading Guide (or whatever it’s called), standard for 250 XLT, 4x4, 7.3 would be 5400. 4800 or 5200
Spring rate goes up from there based on added options. I only added elocker, remote start, upfitter switches, and fog lights. Based on the guide those options still had me at standard springs, so I expect the HSFS will get me 5600’s.
Old Feb 16, 2022 | 10:00 AM
  #68
4wd6.7L's Avatar
4wd6.7L
I don't think I've seen that guide. This is the first I've heard of a 5400lb spring rate. I have seen some post 4400 and 4800 spring rates. If not a typo, that is very surprising that a gas F-250 would come standard with a higher front spring rate than a comparable deisel 250 that has 700lb more weight on the front. Like I said, my deisel 250, crew cab Lariat Ultimate has 5200. Either way, I think it's safe to say that you won't have to worry about getting the 5990.
Old Feb 18, 2022 | 08:19 PM
  #69
number9xd's Avatar
number9xd
Found the document 2021-MY-Camper-Loading
I stand correct (thank you), looks like my truck would come with either 4800 or 5200 springs, depending on the chart in the guide (its a little confusing). So, still hoping the HSFS gets me 5600 springs and the truck is fairly level in stock form.
Old Feb 19, 2022 | 12:01 PM
  #70
Chris 86's Avatar
Chris 86
I hope I ordered the right springs. I'm wanting to replace me 5990lb snow plow prep springs with 5200lb tremor springs. The snow plow springs make for a rough ride with the lighter gas engine. Seems like people with the diesel don't mind the ride, probably due to the extra 800lbs the diesel has.
Google searched LC3C-5310-ATA (LAT), but no direct match. Ordered LC3Z-5310-G, which is the only thing I could find with "ATA" mentioned in the description, but doesn't show weight rating, Pretty confusing. 2020 F-350.
Old Apr 13, 2022 | 01:35 PM
  #71
number9xd's Avatar
number9xd
Picked up my truck yesterday and can confirm that with the HSFS package, my truck came with 5200 springs.
Old Apr 13, 2022 | 05:41 PM
  #72
dzdiggin'dude
Let us know how the ride is after you drive it awhile. What are the front and rear measurements? How much rake. Thanks.
Old Apr 13, 2022 | 05:53 PM
  #73
chadstickpoindexter's Avatar
chadstickpoindexter
That sounds right. I have the 6.7L F250 and added the snow plow/camper package and ended up with 5990 front springs.
Old Apr 13, 2022 | 07:47 PM
  #74
DAVE67FD's Avatar
DAVE67FD
For Informational purposes I have 2022 F250 XL, SC, SB, 6.2L GAS With the heavy service front springs.
Front GAWR=4800 LB
SPRING CODE=NNKK
Old Sep 8, 2022 | 09:34 AM
  #75
longbed94's Avatar
longbed94
4wd Low
If the dealer gave you the right ones they will be over an inch longer. -AKA should be ~19.75” and the 5C3Z5310CA ~21”.
hey boss where did you find the length dimensions of both those springs? Could only find length of the 19’
