2020 Front Coil Spring Codes
Old Jan 5, 2020 | 01:07 AM
Joe T's Avatar
Joe T
Here is a Tremor from another video. Screenshot
Think I will be looking into this unless I am not understanding something.
Old Jan 5, 2020 | 01:53 AM
Section179's Avatar
Section179
Very Interesting find. Looks like the day star/ coil spring isolator approach fo a front end lift.
Old Jan 5, 2020 | 02:03 AM
Joe T's Avatar
Joe T
Except 1/2 inch on the ford set up.
So I bet they are running the gasser, I believe 4,400, coils on the 6.7 now and a 1/2 inch spacer. 800lbs per inch springs would explain the half inch drop. They can rate them to 5200 all day if they want.
No larger pad on the gasser maybe or another lighter spring.
Tremor would use the 2019 coils and the larger upper pad.
This is all speculation at this point and just going off what I am seeing.
I would like that Ford upper pad if it is what I think. With my 2019 6.7 with HD coils plus that it would get me a 1 inch lift over stock 5200 coils and i can do a 1 degree caster shim. Perfect set up for me and looks stock.
Old Jan 5, 2020 | 05:34 AM
Sil17SD's Avatar
Sil17SD
Originally Posted by Joe T
I am also curious about the spring pad up top. Screen shots from that 2020 vs 2020 f350 drw in the video I posted.
2020:
2019:
Im 99% that they are oriented 180* opposite and thats whats making them look different. There is a thick side and a thin side because the top of the spring is not flat.
Old Jan 5, 2020 | 08:18 AM
Joe T's Avatar
Joe T
That was my thought too till I saw the Tremor. Look at from another angle.
Old Jan 8, 2020 | 08:43 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Joe T
I looked at 2 19’s and a 2020 yesterday
i saw no difference in the upper perch pad
just info
Keith
Old Jan 8, 2020 | 03:29 PM
Joe T's Avatar
Joe T
Ok thanks for reporting that.
Old Jan 8, 2020 | 04:23 PM
ZooDad's Avatar
ZooDad
im hoping we can get some additional member info on their new 2020
Old Jan 8, 2020 | 04:32 PM
Joe T's Avatar
Joe T
Did you look at a tremor?
Old Jan 9, 2020 | 12:39 PM
ZooDad's Avatar
ZooDad
I haven't seen one in person yet.
But I did get Tremor info 2020 F350 XLT Tremor 7.3 66 LAV **** (Thanks to 67-4-Me)
Old May 2, 2020 | 05:52 PM
dt75flh's Avatar
dt75flh
2020 f350 tremor diesel lariet
spring code on door 77 NN
tag is LAT. part #lc3c-5310-ata.
rear spring part number lc3c-5a975-na
does anyone know why they downgrade the rear gross axle weight on the tremor from 6830 from 7200?..
my buddy has a 2019 limited F350 with the same rear spring code.... but his axle weight is rated for 7200... and everything I could find online says it should be 7200 / the brakes axle tubes Springs Etc... and actually the Tremor tires are rated higher capacity than his 20in limited rims and tires are
Old Jun 22, 2020 | 05:15 PM
sbrennan007's Avatar
sbrennan007
Took a drive over the weekend to the local Ford dealer, for starters they didn't have allot of Super Duty's, they had 3 2020's, all F250's, Gas engines, 2 Reg Cab and 1 Super Cab, all with the Snow Plow Prep package.
The large letters on the spring tag were "LAL". In taking a brief look around, from what I could tell, everything looked pretty much the same as a 2019, same top spring pad and bottom spring perch. Short block on the rear axle. Took a couple pics.....
F250 Gas Snow Plow Prep
F250 Gas Snow Plow Prep, Passenger side, same Spring rubber perch as on my 2019 F350 (they just didn't line up the spring all the way on the pad).
F250 Gas Rear axle, spring and short block
Old Jun 22, 2020 | 10:01 PM
  #28
Ding126's Avatar
Ding126
2020 F350 Lariat 7.3L SRW CC LB Sport pack, ultimate tow pack, 5th wheel prep, 430 gears
front springs LC3C-5319-AMA
Red Letters LAM
Old Jul 1, 2020 | 10:21 AM
  #29
Klutch5000's Avatar
Klutch5000
Any updated info on this subject? Or spring chart?
Old Aug 17, 2020 | 03:00 PM
  #30
stxhunter's Avatar
stxhunter
Just went out to check my 2020 F-250 7.3L Tremor. LAV is the code up top, Full code is LC3C-5310-AVA
