Rear main Seal Replacement
Old Oct 12, 2003 | 07:24 AM
jfgte8296's Avatar
jfgte8296
Any one know if you can replace the rear main on a 351w with 3 speed Auto Tranny without removing the engine? Any hints or should I just keep parking on my gravel overflow parking spot.
Old Oct 12, 2003 | 10:31 AM
wildjon300ci's Avatar
wildjon300ci
You have to remove the transmission to get to it, but it can be done.
Old Oct 12, 2003 | 12:22 PM
jfgte8296's Avatar
jfgte8296
that's not what I wanted to hear.
Old Oct 14, 2003 | 12:06 PM
jfgte8296's Avatar
jfgte8296
Here is the proceedure
Remove the Tranny and slid it back.
Remove flywheel and engine rear cover plate. Avoid scratching or damaging the oil seal surface.
Use an awl to punch a hole into the seal surface between the seal lip and block. Screw the threaded end of a Jet Plug Remover into the hole, and remove the seal.
Clean the oil seal recess in the cylinder block and main bearing cap.
Old Oct 14, 2003 | 07:11 PM
8 Lugs's Avatar
8 Lugs
This is odd, I must be doing something different!
I have done several of them by unbolting the motor mounts, raising the motor with a jack under the balancer pulley, lowering the oil pan, unbolting the oil pump and dropping it into the pan, removing the pan, unbolting and removing the rear main bearing cap and replacing the 2 piece seal.
I wasn't aware that the 85 351 had the 1 piece seal that required transmission removal to replace!
Old Oct 15, 2003 | 07:28 AM
jfgte8296's Avatar
jfgte8296
Worse than that. If it is a one piece there is a TSB that states, you should test other things befor changing this.
Old Oct 15, 2003 | 07:07 PM
8 Lugs's Avatar
8 Lugs
It's a 2 piece seal!
Sounds like you don't really want to do the job, but just talk about it!
Old Oct 15, 2003 | 09:39 PM
82F100SWB's Avatar
82F100SWB
Well, I'll be damned, I don't have my Ford engine manuals here, but a quick look in the parts books indicates that it could be either one...
Evan
Old Oct 16, 2003 | 08:05 AM
locknkey's Avatar
locknkey
I have a 351 Winsor engine and its a two piece seal, mine also needs replacing.......but I'm going to let it go for awhile longer till next year...not wanting to tackle it yet.
