94 E40D trans fluid change
Old Dec 30, 2019 | 11:23 AM
moe67moe's Avatar
moe67moe
94 Ford E350 460 ci E40D transmission Drained transmission by removing pan and drained torque converter How do I replace fluid and procedure to fill converter Thanks
Old Dec 30, 2019 | 12:14 PM
Bobcatbob's Avatar
Bobcatbob
Your half way there. There is the Mark K method.
You will fill the trans & disconnect a line from trans.
By running the motor you will cycle the fluid thru.
Search for it. It's fun to do.
Now what fluid to use will be the tough question.
Bob
Old Dec 30, 2019 | 07:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Use a MERCON V fluid. You don't need to do the flush since you emptied the pan and the torque converter.
Fill the trans through the dipstick tube. Put 10 quarts in then start the engine. This fills the torque converter. Only run the engine for 60 seconds. Use a watch, because the time is critical. Too much time will run the pump dry and cause damage. After 60 seconds shut the engine down. Add another 4 quarts, start the engine, and check the fluid level, You will probably need to add more to get it right, but with this much in the trans you can leave the engine running. Always check the level with the engine running and the trans in park.
Old Dec 31, 2019 | 09:44 AM
moe67moe's Avatar
moe67moe
Thank you gentlemen for the needed help Am at the age where everything takes much longer and the memory is even worse. Happy and a blessed New Years to all Ken
groggf250
Feb 13, 2010 03:44 PM
bill99psd
15
Feb 23, 2007 09:35 AM
voodoolord
May 16, 2005 02:02 PM
