widow wipers
Old Oct 12, 2003 | 05:12 AM
airwick51's Avatar
airwick51
widow wipers
Ive just installed the new 12 volt wipers from Mid-fifty and although they work, they wont park right. It seems that when I have the the motor turned off in park position and the wipers are at the bottom of the window when I turn on the motor the blades first go DOWN,before going up again.Then they park in the right place, but only after going almost down to the cowl. Ive been going through the old threads to see if anyone else had the same problem .DS59F-100 had a similar problem, but did they go down first?? And which nut on the motor did he adjust? the one holding the arm? Why do the blades start off by desending? HELP
