Spin-on Oil Filter
Old Oct 7, 2003 | 02:28 PM
Nawlins56_F600's Avatar
Nawlins56_F600
Spin-on Oil Filter
Does anyone know what filters can be used for the spin-on adapters on a 272? I currently have a Pennzoil PZ-1 on it, but can't find any parts stores that carry them.
Thanks, Daniel.
Old Oct 7, 2003 | 06:47 PM
fartruck's Avatar
fartruck
My 272 inch (car) uses the standard Ford filter - Fram Ph 8a. Truck applications may use a 2 quart spin-on. You should be able to find this on any filter chart. 2 quart are nearly twice as long, but same thread and gasket base.
Old Oct 8, 2003 | 12:06 AM
Earl's Avatar
Earl
The old and venerable Motorcraft FL1-A filter should do nicely. The Fram PH-8A does show up as a cross reference for the FL-1A.
Old Oct 11, 2003 | 01:17 AM
coleman's Avatar
coleman
ph-8a fits my 292.... should be the same in a 272
I converted to wix..i think its a better filter, cant remember the # right now...but should be no prob to cross reference
Old Oct 11, 2003 | 08:16 AM
Okie-Dokie's Avatar
Okie-Dokie
Walked outside and checked what filter is on my F-600. It has a spin on conversion and uses a ph8a ford filter.
Old Oct 11, 2003 | 09:28 AM
Nawlins56_F600
Thanks fellas!!!
Old Oct 11, 2003 | 11:22 AM
286merc's Avatar
286merc
Stay away from the Fram.
I had one on my 239 a few years ago and after about 300-500 miles my oil pressure had dropped in half. Just thought the engine was getting tired.
Found out from a Y Block forum that others had the same problem.
Went back to Motorcraft and had full pressure again.
Old Oct 11, 2003 | 12:24 PM
coleman's Avatar
coleman
right Merc ... ive had several mechanics tell me they wouldnt use a fram for a paper weight! Now i use wix gold in all my cars. Napa carries them here in my area.
Dave
sacramento ca.
Old Oct 12, 2003 | 09:58 AM
bhabben's Avatar
bhabben
Daniel,
I believe that Pennzoil PZ-1 filter is actually made by Fram, so stay away from it. The Motorcraft FL1A is a great dollar value, it's made by Purolator and uses their PURE ONE filter media. The NAPA 1515 is the same filter as the WIX 51515 and either will cost you a little more, locally the NAPA filter is priced cheaper than the WIX. Another thing to be concerned about is the anti-drainback valve, because cold start is when most engine wear occurs. Some engines (not the Y-block, but like the 300) will let you know right away if it has a cheesy anti-drainback valve upon cold start by valvetrain clattering.
Good Luck!
Brett
