Adding a lift pump
Old Jan 2, 2020 | 09:22 AM
Offshore_Outlaw's Avatar
Offshore_Outlaw
Originally Posted by F250_
I've lived the long road of using the Baldwin pre-pump filter (the one sold by many as part of the H&H kit), as well as the Carter lift pump between the pre-pump filter and the stock pump suction inlet. From my experiences and lessons learned, I now run the Racor PS120 in place of the Baldwin and there is NO LONGER a lift pump between the PS120 and the stock pump suction inlet.
Over the course of the 8-10 years I ran the originally described "upgraded" configuration (Baldwin plus Carter), I had to replace the Carter pump twice, and remain convinced that my OEM pump's death was earlier than it should have been due to the run periods of extra load imposed on the stock pump's suction when the Carter pumps died.
You see, the fuel pumps used on our diesels are generally (if not always) positive displacement pumps with tight internal clearances, and they generally create excess pressure drop when you have to pull through the non-operating pump.
When the lift pump runs, though, there is no problem, and it actually boosts the pressure on the discharge of your stock pump. Good, right? Yes, and no. Whatever additional pressure you gain by running a lift pump ends up getting lost (more accurately, thrown away) once the fuel gets to the fuel pressure regulator on the fuel bowl in the valley.
So, you may end up feeling better by knowing that the lift pump is boosting your fuel pressure from the stock pump (I know that I felt better -- before the sum of the experience). The bottom line for me is that I've not yet seen or heard of a lift pump scenario where the lift pump outlives the stock pump, and WHEN the lift pump doesn't run, it will most likely result in undue strain on the stock pump which will shorten the stock pump's life.
YMMV
I have not installed the second pump yet, the housing that it came with can be used with or without the pump...so it’s Basically just a filter. I have the pump that came with it and was thinking of installing it but the mood I gather is that the factory pump will be just fine. I have a set of gauges being delivered today and fuel pressure is one of them. I will get it all hooked up tomorrow or Saturday and see what my pressures at. I’m sure it will be fine
thanks again
Old Jan 3, 2020 | 09:37 AM
brian42's Avatar
brian42
Veteran: Navy
For about 10 years I had the H&H with a Baldwin BF1212 and the original fuel pump with no issues. For about the last 4 years of that I had updated my turbo with a rebuild kit and billet wheel and installed the FRx (middle spring good for 62-65 psi) and still had no issues (pushing 30 psi of boost). This was all SOTP as I had no fuel pressure gauge.
Then came the serious PMS...sticks. I installed 160cc/80% single shots along with custom tuning (obviously). My "supporting" fuel mods for this upgrade were a new Bosch fuel pump (to replace my original one that I'm sure was tired after a 310K mile career), I swapped out my Baldwin for a Racor PS120-02, and I installed a fuel pressure gauge). Even at WOT with the new tuning/injectors, fuel pressure never dipped below 50 psi and it would immediately recover.
Bobbys Big Red Rig
Jun 20, 2017 08:55 PM
radjcw5
Apr 24, 2017 02:26 AM
Shawn MacAnanny
16
Feb 17, 2016 04:20 PM
Dodge/Cummins
Jun 19, 2008 12:31 PM
WMRiceman
Dec 28, 2006 09:14 PM
