Sponsored by: Real Truck
HELP!
Old Dec 28, 2019 | 07:03 PM
hawkrider's Avatar
hawkrider
HELP!
I have a 2004 F-250 6.0. I started the truck and started driving down the road. Noticed that the power seemed to be less. Started up a small Hill and ended up flooring the petal but was still slowing. Pulled over and put it into park. Tried revving the engine and bearing got the tachometer to move. Went to put it into park and it died. I tried to restart and it would crank but not start. I ended up towing it home. Went out the next day and the truck was dead. Tested the batteries and had a bad battery. I replaced both batteries and plugged the truck in. Went to start it after the truck warmed up and it cranked for a while and then fired up but was week. Still have no throttle response. No blue smoke coming from the tailpipe. I got under the hood with the truck idling. I noticed a humming/whining sound coming from under the passenger side cover. I dont know a lot about diesel's. I need help troubleshooting it.
Old Dec 28, 2019 | 07:15 PM
Colorado350's Avatar
Colorado350
Since it was an electrical issue that started the problem, try disconnecting the batteries again, leaving them disconnected for 20 minutes then try again. Maybe you’ll get lucky and it’s just needs an electrical reset.
Old Dec 28, 2019 | 07:17 PM
hawkrider's Avatar
hawkrider
The truck had no batteries in it for over an hour.
Old Dec 28, 2019 | 07:43 PM
Colorado350
Yes, but when you put new batteries in the system still potentially still had the corrupted electrical codes from the bad batteries. Installing new batteries, then disconnecting them may reset everything...just a thought. Electrical surges can reek havoc on the PCM, disconnecting the batteries is free and quick, if it doesn’t work then you keep looking.
Old Dec 28, 2019 | 07:44 PM
hawkrider's Avatar
hawkrider
I will give that a try tomorrow. Thanks
bluwaterbrew
6.7L Power Stroke Diesel
15
Sep 18, 2019 09:24 AM
xDrizzyDre02x
Modular V10 (6.8l)
Sep 13, 2019 08:41 AM
Jersey__6.4
6.4L Power Stroke Diesel
Apr 25, 2017 10:50 AM
augsburger
15
Feb 6, 2017 11:45 PM
misscali91
38
Mar 1, 2016 04:44 AM
