Intermittent Battery Light
Old Dec 28, 2019 | 03:46 PM
KY_FORD's Avatar
KY_FORD
Question Intermittent Battery Light
I’ve tried to search for a situation like the one I’m having but nothing has popped up.
I have an 06 f350 with the 6.0L dual alternator set up. About half the time after start up, my battery light will come on for 1-2 min then turn off. This only happens after startup. I e had the batteries and top alternator checked ay a parts store multiple times and each store says they’re good. I’ve also check voltage on both batteries and I come up with 12.54/12.56.
this is my first diesel so I understand the battery drain of the glow plugs and I suspect this is related but I doubt that it should happen. I’m also not familiar with a dual alternator setup and how it may change the way you should test for charging issues.
Thanks for your input.
Old Dec 28, 2019 | 06:39 PM
Bently_Coop's Avatar
Bently_Coop
I'd check and clean all of the positive and ground connections.
I'd also recommend moving this thread to the 6.0 section. Maybe @Krewat @Tom or @redford can help.
Further I believe @Too Many Toys has some information on balancing the batteries to look into.
Old Dec 28, 2019 | 06:44 PM
Tom's Avatar
Tom
Moved to the 6.0 forum. 🙂
Old Dec 28, 2019 | 06:58 PM
TooManyToys.'s Avatar
TooManyToys.
With a dual alternator setup the PCM flips between the two alternators as the first activated alternator, the second alternator coming on after the glow plugs turn off. So one alternator is alway off with glow plugs.
It may be one isn’t working as it should, but the parts stores testing isn’t catching it, not unusual. It may be a bad diode giving an AC ripple but still showing a decent output, so when the glow plugs are on with the poorly functioning alternator, the DC voltage is OK.
A better testing facility should be able to figure it out, or if you have access to a clamp-on ammeter, when the battery light is on check the alternator to see which is turned on and outputting current.
Old Dec 28, 2019 | 08:33 PM
KY_FORD's Avatar
KY_FORD
Thank you! I appreciate you explaining how that works. I’ll make an appointment with my normal mechanic to have him go a bit further. I was most concerned with figuring out if my FICM voltage was falling too low, but when I monitor the system with FORScan everything looks good.
Old Dec 28, 2019 | 09:01 PM
87crewdually's Avatar
87crewdually
TooManyToys hit it on how it works.
What I see is you said that only the top alternator was tested, which tested good.
I did not see that you had the lower alternator tested. I would get that lower alternator tested next because that maybe the one that is faulty when the PCM randomly picks it.
Old Dec 28, 2019 | 09:04 PM
TooManyToys.
Glad you picked up on the "top" Pete, I read over that and thought both were tested.
Old Dec 29, 2019 | 11:32 AM
DSMMH's Avatar
DSMMH
I not familiar with the dual setup, so I’m shooting in the dark. If you have a volt meter, you can do this test yourself. I would disconnect one alternator and start the motor. See what happens and check charging voltage. If the red lite stays on and the charging voltage below 13vdc, it is probably the bad alternator. If the alternator checks ok, shut down motor and re- connect alternator. Repeat test on other alternator.
Ed
jkiser01
Aug 20, 2021 12:20 PM
Tym
Oct 14, 2018 09:08 AM
KHflatbed
May 31, 2017 10:18 AM
River
Nov 6, 2011 12:19 PM
Benny2002
Jan 23, 2009 02:16 PM
