2003 fuel tank leaking at emissions vacuum ports, fixed!
For years there has been a fuel smell when the tank is full/ near full. I dropped the tank today to replace the fuel pump and found these visual gems.
You can see that it's been leaking at the connector along time. And it's leaked bad enough that there's liquid marks down the tank. The back doesn't look so good either.
Does anyone have thoughts on why this is so bad and what's the right way to fix it?
The following users liked this post:
So I'm on a rain delay after getting the pump removed and replaced. I've done some Google searching and it seems to be a common problem that the vent fitting cracks on these tanks. Not big cracks, but enough to leak.
I ran to Autozone and picked up some plastic tank repair. I'm gonna clean up both vents and coat any imperfections I see in hopes of fixing the leak.
I got the vents cleaned and found a good sized crack on each one in the same place. There crack was every bit 1/16" wide x1/4" long. I took a picture of the front one.
With the flash, crack under the port.
Without the flash, crack under the port.
It was starting to rain again, so I didn't get a pic of the fix, but I put the sealant completely around the port tube and about halfway around the whole vent housing.
This is a pretty major design flaw and safety issue considering it's the gas tank.
Ii sounds like it's good for a temporary fix which gives you time to save up and plan to an R&R replacement with a new one, just so you don't end up stuck somewhere at an inconvenient moment.
Really odd for them to crack like that. Maybe some previous owner tried to pry them out without unlocking them first? You unlock 'em with a quarter turn counterclockwise, then they just pop out. One of the other available Ford parts might fit, with the difference being just the hose fitting orientation. You'd just have to pull it out and compare. But Ford used the same size hole for many years, on many models. Like one from an F150 might be easier to find. Even in a junkyard.
blue76
07-02-2016 06:16 PM
sloppyslim16
19
05-15-2015 05:46 PM
BACAGrizz
09-29-2010 12:03 PM
