351 swap flywheel question
Old Dec 26, 2019 | 07:39 PM
cyclospot's Avatar
cyclospot
I am swapping a 351 into my 96 that had a 302. The motor I bought did not come with a flywheel. The flywheel I bought for the same year is a 1/4 inch thicker. Will it work ok with the hydraulic clutch?
The old flywheel had been faced but I doubt a 1/4 in. I did have a very small shim on it. The new part number from Power Torque is PHT50-738-100816.The old 302 number is E8TR-AA. Thanks for the help.
Old Dec 26, 2019 | 10:22 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I'll take a wild guess here. The flywheel may be thicker, but what matters is the distance from the bellhousing mounting face to the surface of the flywheel. Try installing the old flywheel on the crank and measure this distance. Replace with the new flywheel and recheck. Are the measurements close? If so, you should be good to go.
By the way, do you have a part # for that new flywheel? 351W will have different balance than the 302.
Old Dec 26, 2019 | 10:56 PM
mary-kate's Avatar
mary-kate
The 5.0 and 5.8 flywheel are quite different visually. But, the clutch release assembly is the same between the two, and IIRC is the same for the Rangers and Explorers.
If you are concerned it's not right, look up the measurements on it to compare. Things aren't supposed to be misboxed, but it happens all the time.
Old Dec 27, 2019 | 12:53 PM
cyclospot's Avatar
cyclospot
Just checked and the new flywheel sits back a 1/4 inch further on the engine. I do not have the ford part number for the Windsor.
Old Dec 27, 2019 | 01:23 PM
cyclospot's Avatar
cyclospot
Solution for this flywheel!
A 1993 flywheel would work for my existing clutch. After that Ford used different fingers on the clutch to meet the wider flywheel on the 351W. I am going to go ahead and put a new clutch in that matches my new flywheel.
Thanks to those who replied and a big thanks to the tech support guy at Power Torque! Also, thanks to the one who put that tech support number on the bottom of the box.
Old Dec 27, 2019 | 08:08 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Does the tech support guy know it is going behind a 351 and not a 302?
Old Dec 29, 2019 | 07:03 PM
cyclospot's Avatar
cyclospot
Yes he did. The flywheel needs to match the pressure plate. For my 96 anyhow. Pulled it out of garage and drove it some today. Seems ok to me.
Old Dec 29, 2019 | 07:06 PM
My4Fordtrucks
The flywheel also needs to be the right balance for the engine.
Old Dec 29, 2019 | 07:08 PM
cyclospot's Avatar
cyclospot
Yes sir, that's why I bought a new flywheel for the 351W.
ford_boy_1996
Nov 13, 2007 08:15 PM
oldmansimek
Mar 11, 2007 03:34 AM
tsi9973
Apr 22, 2006 09:29 PM
Captain_stuck
Engine Swaps
Nov 16, 2004 12:57 AM
fordifieds
Dec 21, 2002 11:58 AM
