Dual Steering Stabilizer?
Old Dec 26, 2019 | 04:57 PM
2003EXV10's Avatar
2003EXV10
Had front end alignment checked today, and shop recommended dual stabilizer. Anyone done this? Necessary addition? Thanks!
i guess I should add that I experienced a bit of vibration, so after alignment was checked and all the front end parts were okay they said the only other solution was the dual stabilizer.
Old Dec 26, 2019 | 06:25 PM
EXSwap's Avatar
EXSwap
@pirate4x4_camo will have the technical explanation, but IMHO, there’s other stuff to check. Wheel balance, tire condition, u-joints, shocks, heck even driveshaft balance before going to dual stabilizers. Are you on stock suspension? Tire size? From what over read, dual stabilizers aren’t something you’d need unless you’re doing some fairly serious wheeling. Certainly not a fix to a vibration problem.
Old Dec 26, 2019 | 07:00 PM
2003EXV10's Avatar
2003EXV10
Thanks! I figured it was a bit overkill. Everything on the front end is good to go, I do have Bilstein shocks on deck but hadn’t noticed any tire wear indicating the urgency.
Old Dec 26, 2019 | 07:02 PM
2003EXV10's Avatar
2003EXV10
Forgot to answer tire size question: I’m running 285/75/16.
Old Dec 26, 2019 | 07:11 PM
pirate4x4_camo's Avatar
pirate4x4_camo
dual steering dampeners are a band aid,
as noted the shop is telling you that you need them because their tech either doesn't want yo deal with it or lacks the skill to find the real cause.
example, with my 37” Tires i can drive any speed with zero detectable vibration, to run the set of 40’s I own i have to install my steering damper or my mirrors rattle so hard I cant see out of them. this is despite the fact they are balanced. the reason being one of the tires is out of round and needs to be shaved.
point being you can either find and fix the problem or but bandaids on it
Old Dec 26, 2019 | 10:15 PM
2003EXV10's Avatar
2003EXV10
Thanks Pirate, I’m going to work on locating the source. I’d rather not bandaid the problem. Will start with double checking tire balance and then have drive shafts checked. I’ve never done driveshaft work, are they balanced? What other service do they need?
Old Dec 26, 2019 | 10:57 PM
SmackDaddy's Avatar
SmackDaddy
Get the problems fixed then get duals IMO
Old Dec 27, 2019 | 09:11 AM
EXSwap's Avatar
EXSwap
Your driveshafts should be balanced form the factory. I'd check the u-joints first if you haven't already. There shouldn't be any play in them. In the most worn case, you should be able to move the driveshaft up and down by pushing an pulling on it. In some cases, you won't be able to with the shaft in the X. You'd have to remove it and feel the joints to see if they are loose or tight and gritty feeling. the other most obvious would be the front axle joints. Those are a little harder to check by hand without removal of the axles, but you should be able to slightly tun the wheels and then reach under there and spin them by hand. If they're bound up, you won't be able to.
Gwilkrrs
6.4L Power Stroke Diesel
15
Jul 7, 2012 05:30 PM
TheBludgeon
Aug 5, 2011 08:31 PM
Kyle 4X4 4life
Feb 3, 2011 09:42 PM
04F-250mark
Texas Chapter
Jan 21, 2011 06:30 PM
