Just click click
Old Dec 22, 2019 | 12:29 AM
ethanshane07's Avatar
ethanshane07
Just click click
I have a 78 f150 with a 400. Drove 3 hrs no problems 2 day for. Parked it for the night. Wouldn't turn back on next day. Just clicked when I tried to start. The battery is charged. Put the multimeter on it everything is good there. I checked the grounds on it and the starter relay. Tried replacing starter after I tested it and found that it wouldn't spin when hooked to battery. Still nothing. I tried to bypass starter relay with screwdriver. Just sparks. Could it be the ignition switch? Ideas?
Old Dec 22, 2019 | 12:32 AM
broktruk's Avatar
broktruk
Initial feeling is to remove the battery post clamps, clean them well and put em back, make sure they’re tight. What I’ve ran into on a couple different rigs.
edit: the new starter wouldn’t spin? Sounds like a bad battery
Old Dec 22, 2019 | 07:42 AM
Tedster9's Avatar
Tedster9
Ho, ho, ho!
Who wouldn't go?
Ho, ho, ho!
Who wouldn't go!
Up on the housetop,
Click, click, click,
Down thru' the chimney
With good Saint Nick.
So, how exactly did you check the grounds?
Old Dec 22, 2019 | 08:35 AM
alans77crew's Avatar
alans77crew
Might also take a good look at battery cables have had them corrode in the middle under the insulation
Old Dec 22, 2019 | 10:01 AM
caravaggio2000's Avatar
caravaggio2000
This. If you are 100% sure the grounds are good (double check) this is the next best guess.
Old Dec 22, 2019 | 11:50 AM
72rtchallenger's Avatar
72rtchallenger
If you bypass starter solenoid on firewall it should crank ,,if you put 12 volts on the side that runs to starter it should crank over
Old Dec 22, 2019 | 02:50 PM
Tedster9's Avatar
Tedster9
Careful (if a manual xmsn) that it is in neutral when bypassing. Don't take out the garage door with your truck, Mama will not be happy.
Can also try banging on the starter case a few healthy raps with a small sledge or hammer, and see if it turns over then. If successful it means a new starter is in your future.
dsmedic
Sep 4, 2019 02:09 PM
SgtHch
Nov 18, 2014 03:57 PM
padd54
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 14, 2012 03:53 AM
80skeys
Nov 2, 2009 08:50 PM
masatcass
Nov 28, 2007 01:23 PM
