240 Vacuum Advance ????????
Old Dec 21, 2019 | 10:38 PM
old28's Avatar
old28
I am looking for new Adjustable Vacuum Advance unit for a spare Autolite 12127 P&C distributor that is from a 1974 E100 Econoline Van that was in the state of KS. Pictures show some detailed measurements of the 240 3.9L unit & the 300 4.9L unit. They are not the same. Anyone know where I can get a new one for the 240 unit?
Well the old 240 unit that has the wider mount (.480") came out of 1974 Ford E100 Econoline van that had a 240 3.9L inline 6. The distributor is an Autolite 12127 points & condenser unit. I have installed the oil pump shaft to the bottom of the distributor and dropped the unit in a 300 block to make sure it fit both the oil pump & block. The vacuum advance is adjustable 7 turns full open to full close with a 1/8" allen. The van was in KS. I want to replace the old adjustable vacuum advance with a new adjustable one when I convert the P&C system to a Pertronix Ignitor 1 setup.
The two pictures show the difference between a new 1971 300 4.9L unit and the old 1974 adjustable advance mounts & shaft. Measurements may be + or - .001-.002", just trying to show the difference. Anyone know where I can find a new unit for this 12127 distributor?
Old Dec 22, 2019 | 07:51 PM
old28's Avatar
old28
Even though the distributor was taken out of a 1974 E100 van it might not be the original that came with the OEM 240 3.9L that was in it. Might have been from any 240 motor say from 1965-74 or whenever they built the first 240 3.9L.
Old Dec 23, 2019 | 12:08 AM
annaleigh's Avatar
annaleigh
Rock Auto lists only 1 for a 1974 with a 3.9 engine. It s a duel port vacuum advance though.
An ebay listing also shows the duel port to fit your van
https://www.ebay.com/itm/VACUUM-ADVA...QAAOSwQItUHYPQ
Perhaps it is not the original distributor, or engine?
RA ford part numbers
Alternate/OEM Part Number(s): D2BZ12370A, D2DZ12370A, D2TZ12370A, D2UZ12370A, D3DF12370AA, D3DZ12370A, D4UZ12370B, DD637
Old Dec 23, 2019 | 04:54 AM
KULTULZ's Avatar
KULTULZ
Post
On the DIST BOWL will be stamped ID NOS. Post those.
Old Dec 23, 2019 | 09:25 PM
old28's Avatar
old28
Only numbers I can read are cast numbers 12127, below it is 6AB, end of 12127 is A11. I can not make out the stamped number to the left of the 12127. I do not have the E100 Econoline van, only the distributor. The motor 240 3.9L inline 6 is the original motor as per the original owner, he was not sure about the distributor.
Old Dec 24, 2019 | 01:40 AM
annaleigh's Avatar
annaleigh
I am just guessing but there should be a D*UF- or D*TZ- or D*AF- in front of the 12127. The * being a number of 0-3
The number should look something like D3UF-12127-A11 and would be the engineering number.
Old Dec 24, 2019 | 05:01 AM
KULTULZ's Avatar
KULTULZ
Post
That stamping is a DIST ASSEMBLY ID NO. Using it directs one to the exact parts list in the MPC.
Without it, most everything is a wild guess.
Old Dec 24, 2019 | 08:17 AM
baddad457's Avatar
baddad457
Just FYI, 12127 is the number found on all Ford distributors.
Old Dec 24, 2019 | 01:26 PM
annaleigh's Avatar
annaleigh
Is there a number or any markings stamped on the vacuum advance itself?
Old Dec 25, 2019 | 09:55 PM
old28's Avatar
old28
annaleigh -- can not make out any real numbers or letters before 12127, looks like the ending letter might be an F but not sure, does not look like a D to start. There is no number on the vacuum advance (only a red dot). Will try to post pictures Thur PM.
Old Dec 26, 2019 | 09:27 AM
KULTULZ's Avatar
KULTULZ
Post
A re-builder will usually remove the STAMPING ID NO as the DIST will lose its original calibration.
Old Jan 2, 2020 | 10:31 PM
old28's Avatar
old28
Still looking for information & type distributor on this E100 Econoline 240 3.9L.
The original vacuum advance has a thicker mounting pad on the distributor side as shown on post # 1 & 2 in this thread.
Couple of distributor pictures are as follows
old28
Feb 24, 2024 08:15 PM
old28
Dec 2, 2019 09:24 PM
cdherman
Sep 28, 2003 01:51 PM
cdherman
Sep 27, 2003 12:11 AM
Herman
Sep 26, 2001 10:47 PM
