Does anyone know if a 1948 3 speed shifter will fit in a 1939 3 speed transmission. I put a 1939 transmission in my 1948 f1 and wanted to keep it looking as original as I can. The swan shifter is nice but doesn't look right. It also hits the dash in reverse and third. Are the shifters interchangeable?
Thank you
Yes.
If you put a ‘39 transmission in a F1...
it had to have some F1 or 42 up truck parts.
The 39- mid year 51 top shifts were the same design.
Mac Van Pelt has a lot of parts and info on these.
A '39 trans would be for a closed driveline, wouldn't it?
That would be correct. Open driveline in Ford cars didn't occur until 1949. I believe pickups got it in '42, but the old memory is starting to get a little fuzzy on this stuff I don't need to recall often anymore. But for sure 39's still had closed drivelines. A lot of the light duty 3 speed parts interchanged for many years, and I'd have to go through the catalogs again to remember all the details. The top loader handles may interchange, but you'd still have the output and driveshaft issue to deal with.
The person that built the 1939 transmission used a open drive tail shaft, so it bolted right in to my 1948 F1, which was already open drive, and I have already been driving it. I just want the shifter to look year correct. I suppose if nobody has a correct '48 shifter, I could heat and bend the swan shifter, but I really hate to do that.
