Sponsored by: Auxito
Cigar lighter fuse
Old Dec 21, 2019 | 11:11 AM
JimNich's Avatar
JimNich
Cigar lighter fuse
I have a 2002 F150 that blows10 amp cigar lighter fuse when I plug in RoadPro 150 watt defroster accessory. Any thoughts
Old Dec 21, 2019 | 12:59 PM
ford390gashog's Avatar
ford390gashog
Well kinda obvious, you are pulling 12.5 amps through a 10 amp fuse it's not going to work.
Old Dec 21, 2019 | 01:51 PM
steve(ill)'s Avatar
steve(ill)
volts x amps = watts ................ if you have 12 volts and 8 amps ( stay under 10)... then you can run about 100 watt unit.
Old Dec 21, 2019 | 01:52 PM
steve(ill)'s Avatar
steve(ill)
if you want to run a 150 watt heater, then you need to put in a NEW accessory plug with 12 gauge wires and a 20 amp fuse.
Old Dec 22, 2019 | 06:24 AM
JimNich's Avatar
JimNich
Thanks, not much electricity
Rusty_S
Electrical Systems/Wiring
Feb 20, 2014 08:36 PM
svastano
May 16, 2007 01:00 PM
f1fordguy
Jul 19, 2006 04:09 PM
Mr.Ford 351W
General Automotive Discussion
Dec 28, 2005 09:18 PM
jasond5150
Jun 17, 2004 11:10 PM
