Sponsored by: Real Truck
Help e99 7.3 Crank no start!
Old Dec 19, 2019 | 11:35 PM
Kingofclouds's Avatar
Kingofclouds
Angry Help e99 7.3 Crank no start!
My truck was driving just fine I went to the store turn my truck on it died suddenly got it to turn back on died about 10s later never started again I have replace both batteries, icp, IPR water pump, fuel pump, fuel filter, fuel bowl element, starter and now I found out the left side of my injectors don't get any power I checked the connection from the idm and the valve covers what do I need to do I had a mechanic come out he said I need a new pcm and my rpm are around 100-200 turning the truck
Old Dec 20, 2019 | 05:46 PM
Colorado350's Avatar
Colorado350
@Kingofclouds
Welcome to FTE.
First, the parts/sensors you’ve replaced, was this done before or after the no start?? If it’s after, stop throwing parts at it, it makes it hard to determine the actual problem.
‘We’re all the sensors OEM? These trucks do not like aftermarket sensors!
When you’re trying to start it do you have the WTS light??
Is the tin nut tight on your IPR?
‘Check you 42 pin connector AND the wires underneath.
Old Dec 20, 2019 | 08:03 PM
Kingofclouds
It was replaced after the no start, all parts was either OEM or motorcraft, my wts comes on, the nut was tight on it I can recheck it, 42 pin on which connection. My codes that popped up were(checking again tomorrow) and not sure why but the Guage for my water temp is all the way up but not on the cluster
P0381
P0603
P0470
P1280
P0472
P1139
Old Dec 20, 2019 | 08:09 PM
Colorado350
Here’s a list of 7.3L codes for reference:
7.3 L Trouble Codes7.3 POWER ST. TROUBLE CODES
KOEO = KEY ON ENGINE OFF
KOER = KEY ON ENGINE RUNNING
(P0106 OR P0107 OR P0108) = KOEO OR CONTINUOUS DTC
P0106=P0107=P0108 INDICATES BAROMETRIC PRESSURE SENSOR READINGIS NOT WITHIN SPECS.
(P0112 OR P0113) = DTC P0112 INDICATES THAT INTAKE AIR TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE LOW.
DTC P0113 INDICATES THAT INTAKE AIR TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE HIGH.
(P0117 OR P0118) = DTC P0117 INDICATES THAT ENGINE COOLENT TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE LOW.
DTC P0118 INDICATES THAT ENGINE COOLENT TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE HIGH.
(P0122 OR P0123) = DTC P0122 INDICATES ACCELERATOR PEDEL SENSOR CIRCUIT INPUT IS LOWER THEN EXPECTED.
DTC P0123 INDICATES ACCELERATOR PEDEL SENSOR CIRCUIT INPUT IS HIGHER THEN EXPECTED.
(P0196 OR P0197 OR P0198) = DTC P0197 INDICATES THAT ENGINE OIL TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE LOW.
DTC P0198 INDICATES THAT ENGINE OIL TEMP SENSOR SIGNAL CIRCUIT IS OUT OF RANGE HIGH.
(P0220 OR P0221) = NOTE;WHEN PERFORMING KOER SWITCH TEST WAIT 5 SECONDS AFTER PRESSING THE TRIGGER TO START TEST
BEFORE RUNNING THRU DRIVER-OPERATED CONTROLS.
(P0236 OR P0237 OR P0238) = POSSIBLE INCORRECT MAP SENSOR ON 1995-97 VEHICLES.DTC P0236-P0237-P0238 INDICATES
A TURBO BOOST SENSOR CIRCUIT AND PERFORMANCE CONCERN.
(P0261-P0284) = (WARNING)DO NOT PERFORM INJECTOR TESTS DURING ENGINE RUNNING!!!(HIGH VOLTAGE 115 VOLTS)
INJECTOR DRIVER MODULE IS CAPABLE OF DETECTING INDIVIDUAL INJECTOR SHORTS AND OPEN TO
EITHER GROUND OR BATTERY WHILE THE ENGINE IS RUNNING.
(P0340 OR P0341 OR P0344) = ENGINE TORQUE AND FUEL IS CONTROLLED AND DEPENDENT ON ENGINE SPEED. FUEL QUANTITY
IS DETERMINED BY ENGINE SPEED.
(P0380 OR P0381) = (WARNING)DO NOT PERFORM INJECTOR TEST DURING ENGINE RUNNING!!!(HIGH VOLTAGE 115 VOLTS)
KEY OFF DISCONNECT CONNECTOR AT VALVE COVER. MEASURE RESISTANCE AT EACH GLOW PLUG,
RESISTANCE SHOULD BE LESS THEN (5ohms).
(P0470-P0478) = (YOU NEED A SCANNER FOR THIS)
(P0503) = (YOU NEED A SCANNER FOR THIS)
(P0560 OR P0562 OR P0563) = NOTE; DTC P0563 MAY BE A TEMPORARY CONDITION WITH A 24v JUMP START.
DTC P0562 MAY BE A TEMPORARY CONDITION AT CRANK WITH LOW BATTERYS.
(P0566 OR P0567 OR P0568 OR P0569) = (YOU NEED A SCANNER FOR THIS)
(P0571 OR P0703) = (YOU NEED A SCANNER FOR THIS)
(P0603) = CONTINUOUS DTC P0603 INDICATES PCM HAS EXPERIENCED A POWER INTERRUPT IN KAM CIRCUIT.
(P0605) = EXISTS ONLY WHEN THERE HAS BEEN AN INTERNAL FAILURE OF PCM. RERUN SELF-TEST. IF DTC P0605 IS
RETRIEVED SUSPECT FAULTY PCM.
(P0606) = EXISTS ONLY WHEN THERE HAS BEEN AN INTERNAL FAILURE OF PCM.(NOTE)IF DTC P0606 IS RETRIEVED WITH
OTHER DTCs,SERVICE ALL OTHER DTCs.
(P0704) = (YOU NEED A SCANNER FOR THIS)
(P0705-P0707 OR P0708) = CONTINUOUS DTCs P0705-P0707-P0708 INDICATES (MLP) CIRCUIT VOLTAGE WAS BELOW
ALLOWED MINIMUM SPECS.
(P0712 OR P0713) = DTC P0712 INDICATES TRANS FLUID TEMP (TFT) SENSOR INPUT BELOW MIN VOLTAGE
DTC P0713 INDICATES (TFT) SENSOR INPUT IS ABOVE MAXIMUM ACCEPTABLE VOLTAGE.
(P0751 OR P0752) = KOER OR CONTINUOUS DTC P0751 INDICATES (SS1) PERFORMANCE MALFUNCTION.
POSSIBLE CAUSES ARE:FAULTY HARNESS CONTINUITY,FAULTY SOLENOID OR HARNESS.
(P0781 OR P0782 OR P0783) = CONTINUOUS DTC P0781 INDICATES GEAR# INCORRECT RATIO. POSSIBLE CAUSES ARE:
INTERNAL TRANS PROBLEM,FAULTY SHIFT SOLENOID,FAULTY PCM.SOLENOID CIRCUIT OPEN
OR SHORTED TO V-POWER OR GND, V-POWER CIRCUIT OPEN OR SHORTED.
(P01184) = INDICATES THAT ENGINE OIL TEMP IS NOT WARM ENOUGH TO PERFORM KOER CYLINDER CONTRIBUTION SELF-TEST.
(P1209 OR P1211) = CONTINUOUS DTC P1209 & P1211 INDICATES THAT INJECTOR CONTROL PRESSURE WAS ABOVE OR BELOW
DESIRED LEVEL UNDER NORMAL DRIVING CONDITIONS.
(P1210 OR P1212) = KOEO P1210 OR P1212 INDICATES INJECTOR CONTROL PRESSURE SIGNAL VOLTAGE WAS GREATER THEN
EXPECTED.
(P1218 OR P1219) = CONTINUOUS DTC P1218 IS SET WHEN THE CYLINDER IDENTIFICATION CIRCUIT IS INTERMITTENTLY
SHORTED TO POWER.
CONTINUOUS DTC P1219 IS SET WHEN THE CYLINDER IDENTIFICATION CIRCUIT IS INTERMITTENTLY
SHORTED TO GROUND.
(P1247 OR P1248) = POSSIBLE INCORRECT MAP SENSOR ON 1995-97 VEHICLES.
(P1280-P1281-P1282-P1283-P1284) = KOEO OR CONTINUOUS DTC INDICATES INJECTOR CONTROL SIGNAL CIRCUIT OUT OF
RANGE LOW WAS DETECTED.
(P1291 OR P1292) = (WARNING)DO NOT PERFORM INJECTOR TEST DURING ENGINE RUNNING!!!(HIGH VOLTAGE 115 VOLTS)
(P1218 OR P1219 OR P1298 OR P1667 OR P1668) = THESE DTCs INDICATE THAT PCM HAS DETECTED A CONCERN NO CID
LINE.POSSIBLE CAUSES ARE:FAULTY PCM OR IDM,OR OPEN OR
GROUNDED CIRCUIT.
(P1316) = INDICATES THAT IDM DTCs ARE STORED IN IDM.
(P1391 OR P1393 OR P1395 OR P1396 OR P1397) = DTCs P1391 & P1395=RIGHT BANK.
DTCs P1393 & P1396=LEFT BANK. CHECK RESISTANCE OF GLOW PLUG
RELAY,SHOULD BE ABOUT 1.0 TO 8.0 OHMS;
(P1464) = INDICATES THAT A/C WAS ON DURING KOER CYLINDER CONTRIBUTION SELF-TEST.
(P1531) = (YOU NEED A SCANNER FOR THIS)
(P1536) = IS SET WHEN PCM DOES NOT SEE PARKING BRAKE APPLIED STATE CHANGE DURING KOER.
(P1660 OR P1661) = INDICATES THAT OUTPUT CIRCUIT CHECK IS HIGH OR LOW.POSSIBLE CAUSES ARE:HIGH SYSTEM
VOLTAGE, VREF CIRCUIT FAULT;
(P1662) = IS SET WHEN A FAULT IS DETECTED ON IDM-EN CIRCUIT.POSSIBLE CAUSES:OPEN IDM-EN CIRCUIT,BLOWN MAXI FUSE.
(P1663) = INDICATES A FAILURE ON THE FUEL DELIVERY COMMAND SIGNAL LINE.
(P1668) = INDICATES A PCM-IDM COMMUNICATION ERROR ON EF LINE.
(P1700 THROUGH P1999) = ARE TRANSMISSION CODES
((TRANSMISSION CODES))
P1702-P1704-P1706 = INDICATES DIGITAL TRANS RANGE SENSOR INTERMITTENT SIGNAL
P1711 = (KOEO-OR-KOER) INDICATES (TFT) SENSOR INPUT OUT OF RANGE
P1713 = DURING (KOEO-KOER) OR CONTINUOUS INDICATES (TFT) CIRCUIT INPUT IS BELOW ACCEPTABLE
VOLTAGE
P1728 = INDICATES INTERNAL TRANS SLIPPAGE
P1740 = INDICATES (TCC) SIGNAL ERROR
P1744 = INDICATES (TCC) SYSTEM PERFORMANCE ERROR
P1746-P1747 = INDICATES (EPC) SOLENOID OPEN CIRCUIT LOW INPUT
P1748 = INDICATES ELECTRONIC PRESSURE CONTROL ELECTRICAL FAULT
P1754 = INDICATES (CCS) ELECTRICAL MALFUNCTION
P1760 = INDICATES (EPC) SOLENOID CIRCUIT INTERMITTENT SHORT
P1779 = (KOEO-KOER) INDICATES TRANS CONTROL INDICATOR LAMP CIRCUIT FAULT
P1780 = INDICATES TRANS CONTROL SWITCH NOT CYCLED DURING TEST
P1781 = INDICATES 4X4L SWITCH FAILURE EITHER OPEN OR SHORTED
P1783 = INDICATES TRANS OVER HEAT CONDITION
P1784 = INDICATES INTERNAL TRANS MECHANICAL FAILURE IN FIRST & REVERSE
P1785 = INDICATES INTERNAL TRANS FAILURE IN 1st & 2nd
P1900 = (KOER) INDICATES FREQUENCY OR VOLTAGE OF THE (OSS) IS INTERMITTENT OR INSUFFICIENT
P1901 = (KOER) INDICATES FREQUENCY OR VOLTAGE OF THE (TSS)IS INTERMITTENT OR INSUFFICIENT
Old Dec 20, 2019 | 08:12 PM
Colorado350
P0381
P0603
P0470
P1280
P0472
P1139
What does the truck do? Just cranks? Have you tried starting it in neutral? So just to eliminate a potential problem, unplug the fuel bowl heater then replace fuse 30 under the dash. See if the truck starts...
Old Dec 20, 2019 | 09:57 PM
Kingofclouds
I have tried to start the truck in neutral and nothing I will unplug the fuel bowl and Change the fuse in the morning. Yes it just cranks it doesn't sputter or even try to start
Old Dec 24, 2019 | 08:05 AM
Colorado350
Any luck with your truck?
Bigointhehizzy
Nov 12, 2019 10:23 PM
Laura Murphy
Sep 6, 2019 09:51 PM
luny1
Apr 18, 2019 05:30 PM
Lockholder
Dec 29, 2018 07:17 PM
afonda
Jan 29, 2012 08:56 PM
