4 Barrel for 360
Old Dec 18, 2019 | 09:04 PM
MeanGreen72's Avatar
MeanGreen72
4 Barrel for 360
Looking at getting an OEM 4 barrel intake for my 1972 F250, 360 2bbl. The 4 barrel has casting number of C4SE-9425-A. Would this work with my stock 360 heads? Or will the ports not match? He also has a couple sets of heads available, one set casting numbers C7AE-A, other set is C4AE-G. Maybe either of these might be a better match? Now it is in the plans to rebuild as a 390, as I already have a crank and connecting rods, if this makes a difference. I guess what I'm trying to find out is how big an issue would port mismatch cause.
Old Dec 18, 2019 | 11:51 PM
85e150's Avatar
85e150
Should work fine. Possibly a T-bird manifold.
Those heads will probably work. Check exhaust manifold bolt pattern on the C7.. manifold.
Your engine should have D2TE heads, which are fine and had as OEM hardened seats. (Unless they are worn out or have been ground) Hardened seats last a lot longer with unleaded gas.
This site has the intakes--you have to weed through it for FE, and if you look above, you can switch over to heads, blocks etc
Ford and Mustang Intake manifold
Old Dec 19, 2019 | 06:47 AM
baddad457's Avatar
baddad457
Don't sweat the port mismatch if any. It's not that big a deal unless you're going all out in your build. With a 360 ? They don't make enough power to affect this.
68Ford4Life
15
Nov 20, 2011 08:21 PM
Steve_Uzi
30
Jan 19, 2011 04:30 PM
blisstruck
17
Oct 29, 2010 12:51 PM
jonathanhartsell
Mar 2, 2009 07:39 AM
FE427TP
Jul 7, 2001 03:01 PM
