Yeah I’m not sure if there’s any significance to that module info or not. The TSB states it needs to have calibration version 75.03A or newer. Our scan tool at work shows the software version and a few other things so I can use that for comparison if needed.
If your scan tool shows throttle plate angle at all, it will be in live data. Don’t be fooled by how it’s listed either - there can be multiple PIDS for it listed in different ways - it can be shown as volts, degrees, or percentage and they can be several lines apart (example, near the top of the list it might say electronic throttle signal 0.5 volts but closer to the bottom it might say throttle plate position 12%) so thoroughly read through the full list of data to see if there’s more than one PID.
If it helps, Ford lists the PID as ETC_TRIM in the TSB.
I don't know if this means throttle plate, or throttle position sensor. Readings is engine idle and normal operating temperature. Pics attached. I was concerned about my fuel injectors and took the plugs off all 8. Tested the injectors with tester set on ohms, I got on 200 ohms setting from 13.8 to 14.2 ohms. Injectors still in intake and fuel rail. I'm not sure what they should read, but I know if one of them is reading way off from the others, the pulse coil is bad.
I can't remember, have you done a compression test since you put the timing chain in? If not, that one thing could tell you a whole lot as to if the chain is off a tooth on one side.
Based on your firing order and recorded pressures:
1 150 -9.1% from 8
3 135 -10.0% from 1
7 145 +7.4% from 3
2 155 +6.9% from 7
6 165 +6.5% from 2
5 155 -6.1% from 6
4 140 -9.7% from 5
8 165 +17.9% from 4
Yeah, that would feel rough at idle. Not stalling/bad injector/missing spark rough, but still would be noticeable. See how the groups of plusses and minuses? If it were + - + - + - + - then it'd be less noticeable than the - - + + + - - + on yours. That +17.9% on 8 is just that much worse of a transition. I think many folks (including me) eyeball around a deviation of 10% between highest and lowest as acceptable on a well-used engine. Yours is 22.2% between the 3's 135 and 6/8's 165 . It doesn't appear to be on the edge of failing based on this, but that is a big difference. For a 14 year old pickup with over 150,000 miles on it, I'd say it's not worth an overhaul which you might as well do if you're going to tear it mostly apart to re-ring and hone. Just keep driving it.
My smoke machine finally arrived. No smoke around the intake or plenum gaskets, or any vacuum lines. There was smoke coming out of the fitting that comes out of the airbox to the drivers side valve cover ventilation. One part of me says unmetered air past mass airflow, the other part of me says that don't make sense because there is vacuum at the valve cover ventilation. So one side is drawing vacuum and the other side of the fitting the intake is sucking air. So what do you think? I attached A pic incase I am confusing you. I also had smoke coming from MAF wiring rubber grommet. I wonder if I can put rtv sealant around the leaks so I don't have to but A expensive air intake filter housing?
I can’t see the smoke.
Takes a good bright light so help see small smoke leaks.
Could you put a circle around the smoke in your picture?
Shouldn’t there be a clamp around the accordion pipe where it connects to the square air box?
When you do the smoke test, pull the air filter off and place a vinyl glove over the opening to keep smoke from exiting into the air filter and it’s housing.
My 4.6 don't have A square air box, its round. My camera will not pick up the smoke, I took 4 different pictures and it just wont pick it up. So I took air box off and took 2 pictures, where my test lead is pointing is where the smoke leaks were coming from.
There is a special made clamp that's missing where the intake tube attaches to the flex tube. One off any 4.6 Crown Vic, Grand Marquis, ect should work. Put some silicone around the fitting for the first leak. The leak at the MAF looks like the MAF is not seated all the way down. Could put some sealer there and push all the way down also.
I don't think this is your idle problem, but could help in higher RPM use.
Yeah I didn't think those leaks was my rough idle problem either, but thought I'd show everyone here just to confirm. Yes I installed A brand new Motorcraft PCV valve when I did the intake and plenum gaskets, because the plenum had about 1/2 to 3/4 inch of oil in the bottom.
In your very first picture from a few posts ago, what do you call that “box” on the left edge of the picture that the “accordion” pipe is attached to (where the clamp is missing)?
The first picture in THIS post where you are pointing to a smoke leak, that is the fresh air intake to the PCV system where it picks up filtered air. A leak there will allow air into the intake by way of the crankcase without being seen by the MAF.
The second picture in this post looks like the plug up for the MAF. Again, a leak there is probably not going through the MAF.
I have to disagree with @yardbird, in that these small leaks will effect idle, but will have very little effect at higher RPMs in relation to the amount of air flowing through the MAF.
When you did your smoke test, did you look for smoke at the base of the dip stick tube where it enters the engine block?
I don't understand the ''missing clamp'' I attached A pic of the quick connect tab on the pipe that is green. I didn't look where the dip stick tube goes in the engine block, but I did see smoke coming out of the dip stick tube where the bracket goes around it and is bolted to the cylinder head just above the exhaust manifold. I did smoke test both ways, one with everything hooked up, and the other way with the PVC pipe disconnected and blocked off. I just don't remember which way I seen the dip stick tube leak.
