Shout out for sixes!!
Y'all don't remember, but when the first OHV six was intro'd, it was faster than the V8 that year per Motor Trend (said V8 having been gifted 10 more horsies, 'cause it wouldn't do for it to be rated less than the new six!!).
Now, all my Ford trucks have been OHV sixes, from 170 to 300cid. And they all were just the engine the truck needed.
My current 240cid six will run 80-85 all day long (did 200 miles just a couple weeks ago, all freeway, 75-85 all the way).
It returns 13 mpg in everyday (mostly small town area) driving, and no one ever accused a Ford truck of aerodynamics...
Today, around 4ºF here, and it fired right up, no drama, almost zero cranking, though it wanted a bit more choke than usual...
I've left it for weeks (no need for a truck), and it always fires up immediately.
So, let's hear it from those of us who believe in six in a row!!
the 390 that's in my '64. The old 390 setup has some wierd parts and a carb that's too small and I like sixes.
As a rookie mechanic, I wanted something simple to work with. It sure is!
rtc
I put 15 - 8"x12"x12" & 4 small cement blocks on the fab table. All those blocks add up to 730 #. So now the weight on the back is 1,930+/- a few.
I wanted to see what she'd do with all that weight. Whew! what a solid sturdy smooth ride !
I should say that I have split cast iron exh. mnflds on her now. That has made the motor really come alive.
It is very steep here. I went up a real steep road. Stopped 1/2 way up. Put 'er in Granny low (T-98), She barely strained, up, up and away we went. Not interested in reckless speed. Surety the I-6 does faithfully give.
In the early 60's, I had the priviledge of meeting Charlie Seabrook in the pits of Atco Dragstrip in South Jersey. He had a red hot 6 cylinder Chevy/Gmc. There was even a story in Hot Rod magazine about the car. The title of the article, "6 in a row ain't so slow." Don't remember his times, but I have remembered the 3-2 carbs and the car was fast.
So I am on board, 6 in a row can really go. I am keeping my 240.
I am soon going to take off the fab table & welder and make a dump box to go in it's place. Am drawing it all up now. Currently, I have an 8,000# electric winch on the front bumper. Going to put it behind cab, put a structure over it to pick up dump box with.
I need to add, I took into account the before and after measurements of fab table. Before blocks and after I put blocks on. She sat down 1-1/2" with the 730 # of blocks.
Awe righty then, better stop fur now, Best, Pete
It looks to me like a basic engine overhaul (cylinder hone, rings & bearings &c) would be pretty reasonably done without even having to remove the engine from the truck.
There is just something about the in-line cylinders. Plus the 240/300 uses timing gears rather than a chain. No wonder that motor was made from '65 to '96.
I put cast iron split headers on...What a huge difference in the same engine! I have replaced the oil pump too. I run 20W50 oil. The bearings started to make a little noise on a long uphill grade in 3rd. So, I started using the thicker oil. Nice and quiet now on the same rd.
I am very strict on oil changes. When the 3,000 miles will come in the middle of the upcoming week for the next oil change, I have the oil replaced the weeked before.
No chance I'll use any other motor.
You are real knowledgeable. Would you be able to tell me approx. what my rear end ratio is? Here is what I know : I used to run 15" rims. For me to go 55mph, I'd have to make the speedo needle go to 61 mph. Now I run 16" rims using Michelin radial tires & inner tubes. Now the speedo seems to be correct. No more...61 mph to go 55. I have sent the speedo up to Carl's Speedometer Shop in Pontiac Michigan. So, that is accurate. When I had a job that was 20 miles away, I was getting 19. something mpg. That was part interstate and the rest 4 lane.
Really wondering what the ratio is. Any wisdom you'd care to tell me here ?
Thank you, Pete
Depends on what you really want. l like everything is easy to get to on an I-6.
If you do put in an I-6, put on a set of split exh. headers after you have driven the truck for a while. The motor really comes alive with the split exh.mnfld. You will be pleasantly surprised. I finally did. Ran the stock exh.mnfld for 38 yrs. Now with the motor breathing so so much better, the difference is astonishing. Like I said above, I had a load of 1,900 #'s on board. I made a point of going on a steep rd. I went up half way and stopped. I am very impressed with what happened. I took off just like there was no incline...at all.
I did that because, I wanted to see what a load of gravel (one yard is 2,500 #'s) would be like. The dump box I am going to put on the back of my truck will hold 1/2 yard. That will be 1,200 #'s. So with the welder and fab.table off (they weigh in @ 1,200#'s), my truck will not notice any real difference. Course the dump box will add to the load of gravel. The dump box could weigh as much as 700 #'s (it can't possibly) and my truck could handle the load (1,200 #'s +700#'s for the dump box equals what my test load of 1,900#'s was). I am going to stiffen the frame as part of this job. Bending the frame is not going to happen. I will then be safe within the original design limits of the truck, and will be able to stop.
I need a dump box because the drive way here is narrow. Too narrow for even a small 6 wheeled 3 or 4 yrd dump truck. See, I am putting in a 24'x24' metal fab. shop in the back yard here. Gotta have 6" of gravel put down first before 4" of concrete floor.
I figure I need to dig out 6" of dirt. That is 10.6 yds. Then that much gravel.Then I will use my truck to bring in 6.4 yds. of concrete to go atop the gravel. No concrete truck can fit back there either. My truck will prove herself to be the queen she really is.
Now that I am not working for anyone else, I can devote myself to this work here.
Awe righty then, Best to you, Pete
It is sporting EFI exh. manifolds and the stock intake with stock v1 carb hooked to a T18 but soon to be a NP435 and a 2.75 gear in the 9"
I have also driven other make sixes and liked them also.
Dave ----
