adding a Puddle Light
Old Dec 18, 2019 | 12:25 PM
Frank79's Avatar
Frank79
Would like to add these Rock lights to the bottom of my mirrors. My mirrors do have a defrost function and they are a manual fold in and out.
Is there a power wire that I can tap into in the mirror section so the puddle lights come on when you unlock the doors or open the doors? I know there's power for the blinker and turn signal. But I dont want the puddle light on all the time.
Old Dec 18, 2019 | 02:58 PM
Andy_george's Avatar
Andy_george
Do they stick on? Wonder if 4 of those across the rear receiver would work as additional backup lights?
Old Dec 18, 2019 | 03:59 PM
Frank79's Avatar
Frank79
im sure you can use dbl sides tape. But these have 2 holes for screw mount.
Old Dec 18, 2019 | 05:50 PM
h20camper's Avatar
h20camper
See if you have and then meter the Violet-Green wire going to the mirror. Easiest location to access the harness is pulling the cap off of the inside door trim just opposite of the mirror. Black-Yellow is ground.
Old Dec 18, 2019 | 07:09 PM
Frank79's Avatar
Frank79
This the cap you referring to?
Old Dec 18, 2019 | 07:17 PM
h20camper's Avatar
h20camper
Yup.
Old Dec 18, 2019 | 07:26 PM
Frank79's Avatar
Frank79
Yup.
Just it just snap off? Any tips? Ill work on it tomorrow.
Old Dec 18, 2019 | 07:32 PM
h20camper's Avatar
h20camper
Picture says it all....
Old Dec 18, 2019 | 09:29 PM
Frank79's Avatar
Frank79
thanks a bunch!
Old Dec 19, 2019 | 09:22 AM
Frank79's Avatar
Frank79
Just took the cover off and here is what I see. The top left pin is the running light. The top right pin is the defrost.
None of the other pins react to blinkers, 4 way flashers or anything. They seem "dead". I probed them with door open, closed, truck on and off and got nothing. Only ones for sure are the running lights and defrost.
Old Dec 19, 2019 | 09:58 AM
h20camper's Avatar
h20camper
Looks like you're missing the PIN that would support the Puddle Light.
Old Dec 19, 2019 | 12:19 PM
Frank79's Avatar
Frank79
I guess using this harness for a puddle light is out of the question then?
If the pin you are showing is for the turn signal, how come I didn't get any reaction from it when I probed it? Only 2 pins were working for me.
Old Dec 19, 2019 | 12:36 PM
h20camper's Avatar
h20camper
Sorry, I can't tell you why not. I'm only going off of schematic in Service Manual. Test again? Maybe you had bad meter connection?
Old Dec 19, 2019 | 01:12 PM
Frank79's Avatar
Frank79
New meter.... Heres the results. If your schematic is right about that particular pin being a puddle light, I am getting 5.5v constant. The pin you show for turn signal is dead. Doesn't matter if doors open, locked, engine on or off.
Im baffled
Old Dec 28, 2019 | 08:23 PM
Frank79's Avatar
Frank79
Since the mirror doesn't support a puddle light any recommendations on which fuse I can tap into that will trigger the lights when the doors lock/ unlock? I was looking at interior fuse #3.
